KitchenAid KSM150PSER Speed Control Plate Replacement
  1. KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid KSM150PSER Speed Control Plate Replacement, Speed Control Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the 12mm screw by holding the grounding wire in place and rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the speed control plate.
  4. KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seal from the back of the mixer. Then unhook the spring from the bottom of the speed control plate by using tweezers and pulling it back and out of the plate.
    • Take a rag or towel and hook the spring on the towel so that the hook doesn’t spring back inside the mixer.
    Guten Tag!
    Wenn die Feder ins innere der Maschine zurück gesprungen ist,
    gibt es eine Anleitung, um sie wieder funktionstüchtig zu machen??????
    Vielen Dank für eine Info!
    Raffiraffi - crwdns2934203:0crwdne2934203:0
    @raffiraffi Ich fürchte, dass die Haube nach oben weg muss. Wahrscheinlich geht das ganz ähnlich, wie bei diesem Modell.
    VauWeh -
  5. KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #2 screwdriver, remove the two adjustment screws by rotating them counterclockwise.
    • Before beginning to remove the screws, use a ruler and measure how far the screws are in. These screws determine the speed of the mixer, and not screwing them back in to the same position will change the speed of the mixer.
    What is the default measurement for the screws? I didn’t know I had to do this and already messed around with the screws.
    Nicole Jensen - crwdns2934203:0crwdne2934203:0
    Problem was that lever would not stay in off position without finger pressure and motor would run as soon as plugged in. In shifting the lever,I noticed a slight variation in the grey fork gizmo that protrudes above the bottom screw. That screw protruded 9/32”. I tightened it to 6/32’ and lever turns off the motor.
    David L Kline - crwdns2934203:0crwdne2934203:0
  6. KitchenAid KSM150PSER Speed Control Plate Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The control plate can now be removed by pulling back on the plate.
crwdns2935229:09crwdne2935229:0
Richa Gadgil
crwdns2935283:001/24/18crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G5, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S2-G5, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S2G5
crwdns2935297:011crwdne2935297:0
Thanks for this, but a quick question, when the mixer is switched off, the metal bar on the back of the speed plate at the bottom, is that supposed to rest on the two prongs that stick out towards the bottom of the inside of the mixer? Thanks.
Mark R (dflipb) - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 139
crwdns2942667:0crwdne2942667:0 21,758
