KitchenAid KSB5CR Power Cable Replacement
    1. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
    2. KitchenAid KSB5CR Power Cable Replacement, Removing the Back Panel Part 2: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the back panel up, sliding it along the power cord.
    1. KitchenAid KSB5CR Power Cable Replacement, Freeing the Power Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up on the power cable to pop it out of its holder.
    2. KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid KSB5CR Power Cable Replacement, Detaching the White and Black Wires: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be gentle with the knife or you will break the circuit board.
      • Slide the knife into the metal loop holding the insulation before the white copper wire, and wiggle it back and forth until it loosens.
      • Pull the wire out from the metal loop that you loosened.
      • Repeat this process with the black copper wire.
    3. KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid KSB5CR Power Cable Replacement, Detatching the Green Wire: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Phillips #2 screwdriver, remove the #8 Phillips 6mm screw to which the green wire is attached.
Cameron Geehr
crwdns2935283:009/28/14crwdne2935283:0
745 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-5, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 12-5, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S12G5
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 989
