KitchenAid KSB5CR Motor Replacement
    1. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the glass container and place the blender upside down on a solid surface.
      • Remove the four rubber feet using the needle nose pliers.
      • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
    2. KitchenAid KSB5CR Motor Replacement, Removing the Back Panel Part 2: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the back panel up, sliding it along the power cord.
    1. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 1: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
      • Remove the rubber O-ring by lifting it up.
      • Remove the ribbon cable from the chassis by lifting it up.
    2. KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Motor Replacement, Removing the Fan Chassis Part 2: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unhook the white wire that is looped around the peg by pulling it out of the clip.
      • Repeat this process with the red wire on the other side of the chassis.
      • Remove the end cap using the 8" needle nose pliers.
      • Pull up the fan chassis.
    3. KitchenAid KSB5CR Motor Replacement, Removing the Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the fan by lifting it upwards.
      • This step is difficult and requires force. Use of both hands is recommended.
    1. KitchenAid KSB5CR Motor Replacement, Removing the Metal Cap: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the needle nose pliers to turn the coupling clockwise to loosen it.
    2. KitchenAid KSB5CR Motor Replacement, Removing the Screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate the blender 90 degrees clockwise.
      • Remove the two #8 Phillips 12 mm screws using the Phillips #2 screwdriver.
    3. KitchenAid KSB5CR Motor Replacement, Detatching the Wire: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the knife in the metal loop holding the insulation before the white copper wire, and wiggle the knife back and forth until it loosens.
      • Pull the wire out from the metal loop that you loosened.
    4. KitchenAid KSB5CR Motor Replacement, Removing the Motor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the motor up out of the chassis.
Cameron Geehr
crwdns2935283:009/28/14crwdne2935283:0
745 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-5, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 12-5, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S12G5
crwdns2936753:030crwdne2936753:0 91
crwdns2942667:0crwdne2942667:0 4,928
