KitchenAid KSB5CR Fan Replacement
  1. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 1: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. KitchenAid KSB5CR Fan Replacement, Removing the Back Panel Part 2: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back panel up, sliding it along the power cord.
  3. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 1: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two #5 Phillips 95 mm machine screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
  4. KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 KitchenAid KSB5CR Fan Replacement, Removing the Fan Chassis Part 2: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unhook the white wire that is looped around the peg by pulling it out of the clip.
    • Repeat this process with the red wire on the other side of the chassis.
    • Remove the end cap using the 8" needle nose pliers.
    • Pull up the fan chassis.
  5. KitchenAid KSB5CR Fan Replacement, Removing the Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan by lifting it upwards.
    • This step is difficult and requires force. Use of both hands is recommended.
Cameron Geehr
crwdns2935283:009/28/14crwdne2935283:0
745 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-5, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 12-5, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S12G5
Hi,
Do you know if it is possible to convert Kitchenaid Artisan stand mixer to 240v, has anyone looked inside or know if i should change something.
Ancient warrior - crwdns2934203:0crwdne2934203:0
Does raplacing the fan mean that the fan itself (when broken) can be ordered? So just the white plastic round part. If so, could someone please give me a reference number? Would be highly appreciated.
Hugo, the Netherlands.
Hugo - crwdns2934203:0crwdne2934203:0
my blender turn on all the numbers light at the same time and is not working at all. do you know what the problem could be?
patricia - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,415
