KitchenAid Dishwasher Control Touch Panel Replacement
crwdns2950213:0crwdne2950213:0
crwdns2950215:0crwdne2950215:0
      • Keep the door fully assembled while you confirm the button symptoms.
      • Don't remove door panels or touch the wiring while the dishwasher is powered.
      • Suspect a faulty touch panel if Control Lock won't clear after you hold the key for three seconds.
      • Suspect the panel if keys respond only sometimes, take a long time to react, or work again only after the dishwasher has been powered off for hours.
      • Similar Whirlpool and Maytag models may use a different part number or key layout.
      • Turn the breaker off or unplug the dishwasher before removing any screws.
      • Place a stool under the open door so the door can rest on it.
      • Use a driver to remove the 10 inner door screws.
      • The two center screws are longer, and the four screws on each side are shorter.
      • Keep the two long screws separate from the eight short screws.
      • Keep the door supported because the inner and outer panels can separate once the screws are removed.
      • Lift the outer front panel slightly to release the plastic retainers on both sides.
      • Pull the panel forward just far enough to reach the touch-panel cable.
      • Press the connector latch and unplug the cable.
      • Lift the front panel away from the dishwasher.
      • Set the panel on a stable work surface.
      • Wear work gloves if the metal edges feel sharp.
      • Leave the touch-panel cable unplugged and keep the dishwasher door open.
      • Restore power for this test only.
      • Keep your hands away from the wiring while power is on.
      • Wait about 10 seconds, then close the door fully.
      • Listen for the drain pump to start.
      • If the drain pump starts, the main control board is probably good and the touch panel is the more likely failed part.
      • This test is not definitive, and the drain pump may run for about two minutes.
      • Turn the power off again before handling the panel.
      • Flip the front panel over on the work surface.
      • Locate the three screws that secure the control touch panel.
      • The two nearby end screws secure the handle, not the touch panel.
      • Use a driver to remove the three touch-panel screws.
      • These screws are shorter than the 10 door screws, so keep them in a separate group.
      • Lift the old touch panel out of the front panel.
      • Use a small screwdriver to free any tight tabs or edges.
      • Don't force the plastic because the tabs and trim can break.
      • Mark the old panel if it looks similar to the replacement.
      • Keep the old panel separate until the repair is verified.
      • Keep the door open and bring both touch panels to the dishwasher.
      • If the door closes, pull from the outer edge so you don't tug on the whole dishwasher.
      • Plug in the old touch panel, restore power, and test the problem keys if you want a baseline.
      • Turn the power off before unplugging the old panel.
      • Plug in the replacement touch panel, restore power, and press every key.
      • A good panel should respond consistently to Start, Cancel, Control Lock, and the cycle keys.
      • Turn the power off and unplug the replacement panel before returning to the work surface.
      • Place the front panel on the work surface with the inside facing up.
      • Slide the replacement touch panel into the front panel.
      • Start one side under the retaining edge, especially near the tight screw that may not come out fully.
      • Use a small screwdriver to work the opposite side under the retaining edge.
      • If the lower edge doesn't seat at first, get the panel mostly in place and work it outward until it sits correctly.
      • Don't force the touch panel because the tabs and trim can break.
      • Be patient, since the panel may take a few tries to seat fully.
      • Slide the full panel into its final position once the edges are seated.
      • Use a driver at low torque to install the three shortest screws in the control touch panel.
      • Install the screws in the same three positions they came from.
      • Do not mix these screws with the larger door screws.
      • Snug the screws without overtightening them.
      • Overtightening can strip the plastic or crack the touch panel.
      • Find the metal lip on the front panel and the matching channel on the door.
      • The lip must slide into the channel, so seat the panel from the top.
      • Plug in the touch-panel cable before seating the front panel.
      • Hold the front panel against the door and slide it down from the top until it seats.
      • A helper can make alignment easier.
      • Make sure the door is still supported by the stool.
      • Use a driver to reinstall the 10 inner door screws.
      • Install the two long screws in the center positions.
      • Install the eight short screws along the sides, four on each side.
      • Snug all 10 screws evenly.
      • Stop once the screws are tight and secure.
      • Restore power and wait 5 to 10 seconds for the controls to wake up.
      • Press each key to confirm it responds consistently.
      • Hold Control Lock for three seconds to make sure it can turn on and off.
      • Start a cycle briefly to confirm the Start key works.
      • Use Cancel to stop the cycle.
      • If Control Lock stays on or keys still don't respond, turn the power off and reseat the touch-panel cable.
      • Confirm the replacement part number matches the dishwasher model if the problem remains.
      • The main-control-board test is not definitive, so persistent symptoms may still require main control board diagnosis.
Run a short test cycle and confirm the buttons respond, the dishwasher starts, and Cancel stops the cycle. Repair didn't go as planned? Ask our Answers community for help.
eCuration
crwdns2935283:005/19/17crwdne2935283:0
478,744 crwdns2915208:0crwdne2915208:0
crwdns2935297:0396crwdne2935297:0
crwdns2936753:030crwdne2936753:0 130
crwdns2942667:0crwdne2942667:0 346
