KitchenAid Classic Mixer K45SSWH Beater Head Adjustment
  1. KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 KitchenAid Classic Mixer K45SSWH Beater Head Adjustment, Adjust the height: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the mixer arm and locate the large screw where the base meets the arm.
    • Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
    • The beater head should pass only about 1/16th of an inch above the base of the bowl. One good way to get the height right is to place a dime in the bowl and adjust the height until the beater head barely brushes the dime as it passes.
    Thank you! Problem solved!!!
    mirdel - crwdns2934203:0crwdne2934203:0
    Bravo,ich wusste bisher nicht, wozu die Schraube gut ist!
    Arbeitsgruppe Dialog - crwdns2934203:0crwdne2934203:0
    Der Trick mit der Münze ist gut, eine 5ct Münze sollte bei laufender Maschine nur leicht touchiert werden und ein paar Millimeter in der Schüssel weiter bewegt werden.
    KaiVi - crwdns2934203:0crwdne2934203:0
Once your beater head is at the appropriate height, you're good to go.
crwdns2935229:05crwdne2935229:0
Markus Gemperle
crwdns2935283:010/13/14crwdne2935283:0
720 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-28, Maness Fall 2014 crwdns2935289:0Cal Poly, Team 14-28, Maness Fall 2014crwdne2935289:0
CPSU-MANESS-F14S14G28
crwdns2935297:022crwdne2935297:0
Very helpful. Thank you for the info, it worked!!
suz - crwdns2934203:0crwdne2934203:0
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
Aide L. - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 103
crwdns2942667:0crwdne2942667:0 15,229
