Adjusting the beater head is a simple process involving only some handling of a screwdriver.
Lift the mixer arm and locate the large screw where the base meets the arm.
Using a flathead screwdriver, turn the screw counter-clockwise to raise the beater head or turn it clockwise to lower the beater head.
Once your beater head is at the appropriate height, you're good to go.
Very helpful. Thank you for the info, it worked!!
I have a K5ss by Hobbart. Do you know how to adjust the bowl/beater clearance.?This machine does not have the screw that adjusts the clearance like the K45ss does. The manual tells how to turn a screw to adjust the clearance on a k45ss, but says to consult an authorized dealer for the k5ss. I called around and nobody in my area works on mixers. Is this something I can do myself? Any help would be appreciated.
My Beater Head Adjuster Screw hole's threads are damaged, ( I may have crossed threaded the screw) and the replacement screw will not screw in. I need to have the threads chased. None of the local KitchenAid repair locations work on small KitchenAid small appliances, only stoves, friges, ect.
I need someone close 36801 (Opelika Al) and having no luck finding someone.
Any help greatly appreciated
