Kirby G4 Vacuum Belt Replacement
  1. Kirby G4 Vacuum Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kirby G4 Vacuum Belt Replacement, Belt: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the vacuum from the power source before doing any maintenance.
  2. Kirby G4 Vacuum Belt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lower the height adjustment all the way down.
    • Unlock the belt lifter on the front of the nozzle by turning the belt lifter handle to the left until the red arrows line up.
    • Release the nozzle latch (on the side of the vacuum) and pull the nozzle off.
  3. Kirby G4 Vacuum Belt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the belt lifter handle to the right until the green arrows line up. This will release tension on the belt so you can remove it.
  4. Kirby G4 Vacuum Belt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the nozzle over to access the bottom plate.
    • Use a spudger or pull the tabs (depending on the model) to remove the plate.
    • Lift out the brush roll — the belt will be looped around it.
  5. Kirby G4 Vacuum Belt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the old belt off the brush roll and the motor shaft (if it’s still intact).
  6. Kirby G4 Vacuum Belt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the new belt onto the brush roll first.
    • Position the brush roll back into its slot with the belt over the metal motor shaft.
  7. Kirby G4 Vacuum Belt Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kirby G4 Vacuum Belt Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kirby G4 Vacuum Belt Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the belt lifter handle to the left (red arrows) again — this will stretch and lift the belt into place.
  8. Kirby G4 Vacuum Belt Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kirby G4 Vacuum Belt Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Line up the nozzle with the front of the vacuum. Lock it back into place using the nozzle latch. Turn the belt lifter handle to the right again (green arrows) to re-engage the belt.
  9. Kirby G4 Vacuum Belt Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Adjust the vacuum height back to your desired setting. Plug in and turn on the vacuum to ensure the brush roll is spinning properly.
Carley Gates
crwdns2935283:002/12/25crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
Rose State College, Team 1-5, Kirkman Spring 2025 crwdns2935289:0Rose State College, Team 1-5, Kirkman Spring 2025crwdne2935289:0
ROSE-KIRKMAN-S25S1G5
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 194
