Kinzo 8E116 Motor Bearing Replacement
  1. Kinzo 8E116 Motor Bearing Replacement, remove the head: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove the head: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove the head: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the drill press is turned off and the power cord is unplugged.
    • Loosen tension set screws (on both sides) and make sure tension pulling handle is pushed left.
    • With the 4mm hex key, loosen the set screws holding the head in place on the column.
    • Remove the vertical adjustment handles to prevent them from damaging when removing the head.
    • Remove the v-band from the pulley.
    • Pick up the head from the column and lay it on a table with the on/off buttons facing up.
  2. Kinzo 8E116 Motor Bearing Replacement, disconnect power cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, disconnect power cable: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, disconnect power cable: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the small flathead, remove the screw holding the cover for the motor power cable inlet.
    • Take off the cap protecting the connectors.
    • Loosen the screws holding the cable ends in place and remove the cable from the connector housing.
    • Put the cap back and attach the cover to protect the connector during the rest of this procedure.
  3. Kinzo 8E116 Motor Bearing Replacement, disconnect motor from mount: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, disconnect motor from mount: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, disconnect motor from mount: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the 12 and 14 mm wrenches, loosen the mounting bolts.
    • Turn over the head and loosen the mounting bolts on that side as well.
    • Place the head with back facing up, remove the bolts and remove the motor from the mount.
  4. Kinzo 8E116 Motor Bearing Replacement, remove pulley: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove pulley: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove pulley: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the set screw from the pulley with the small flathead.
    • Remove the pulley from the shaft using a pulley removal tool.
    • The pulley has a diameter of 9 cm at its base.
    • Make sure the inside of the pulley is free of dirt or particles for easy reassembly.
  5. Kinzo 8E116 Motor Bearing Replacement, remove fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws holding the fan cover and remove the cover. A few mallet taps might be needed to encourage the cover.
    • Use a small crowbar to leverage the fan from the shaft.
  6. Kinzo 8E116 Motor Bearing Replacement, remove rotor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove rotor: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove rotor: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the fan side motor housing bolts.
    • Use the mallet to tap around the cover edges and get it to loosen.
    • Once it is loose, the shaft, rotor and housing cover can be pulled from the motor housing.
  7. Kinzo 8E116 Motor Bearing Replacement, remove fan sided bearing: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove fan sided bearing: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove fan sided bearing: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully tap off the cover from the bearing with the mallet.
    • Pull the bearing from the shaft using the pulley removal tool.
  8. Kinzo 8E116 Motor Bearing Replacement, remove pulley sided bearing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove pulley sided bearing: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, remove pulley sided bearing: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The pulley sided bearing is located in the motor housing.
    • Clamp the bearing from the pulley side with the bearing removal tool, and use the mallet to hit it from its seat.
    • Clean the bearing seat.
  9. Kinzo 8E116 Motor Bearing Replacement, replace pulley sided bearing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, replace pulley sided bearing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, replace pulley sided bearing: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before replacement, make sure the shafts, bearing seats, and bearings are clean and lubricated for easy reassembly.
    • Insert the new bearing into the empty seat in the motor housing.
    • Use the bearing removal tool to grip the inside.
    • While centering the bearing, tap the bearing around the outside to press it a little into the seat.
    • Remove the bearing removal tool, and keep tapping around the outside of the bearing until it is fully in.
  10. Kinzo 8E116 Motor Bearing Replacement, replace fan sided bearing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kinzo 8E116 Motor Bearing Replacement, replace fan sided bearing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After cleaning the bearing seat and lubricating the bearing, press it in by hand, or use tapping method from the previous step.
    • Press the cover containing the bearing on the shaft.
To reassemble your device, follow these instructions in reverse order from step 6.
knipwim
crwdns2935283:009/01/18crwdne2935283:0
13.406 crwdns2915208:0crwdne2915208:0
crwdns2935297:039crwdne2935297:0
crwdns2942667:0crwdne2942667:0 666
