Kinzo 8E116 Center Pulley Bearing Replacement
  1. Kinzo 8E116 Center Pulley Bearing Replacement, remove center pulley assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, remove center pulley assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, remove center pulley assembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the drill press is turned off and the power cord is unplugged.
    • Loosen tension set screws (on both sides) and make sure tension pulling handle is pushed left.
    • Remove the v-band from the pulley.
    • Pull the center pulley towards the front, adding slack to the other v-band, and pull the pulley assembly up from the head.
  2. Kinzo 8E116 Center Pulley Bearing Replacement, remove axle: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, remove axle: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, remove axle: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the internal retaining ring with the snap ring pliers.
    • Remove the external retaining ring with the snap ring pliers.
    • Press out the axle with the pulley puller.
  3. Kinzo 8E116 Center Pulley Bearing Replacement, remove bearings: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, remove bearings: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, remove bearings: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The pulley contains 2 bearings separated with a spacing ring.
    • Using the bearing removal tool, pull out the first bearing.
    • Optionally, you can use a socket to tap out the second bearing. Make sure to use a socket that fits the outer ring of the bearing.
    • Pull out the second bearing with the bearing removal tool.
  4. Kinzo 8E116 Center Pulley Bearing Replacement, replace first bearing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, replace first bearing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When pressing in the bearing, make sure the pressure is spread on the inside and outside ring of the bearing.
    • Place the first bearing on the pulley.
    • Press in the bearing to the bottom of the pulley.
  5. Kinzo 8E116 Center Pulley Bearing Replacement, replace second bearing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, replace second bearing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spacer onto the first bearing.
    • Press in the second bearing until it touches the spacer.
  6. Kinzo 8E116 Center Pulley Bearing Replacement, press the axle back in: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, press the axle back in: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kinzo 8E116 Center Pulley Bearing Replacement, press the axle back in: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When pressing in the axle, ensure that the bearings are not pressed out again by supporting the bearings.
    • Use a spacer that can hold in the bearing, but allow the axle to be pressed through.
    • You can 3D print such a spacer, or use the outer ring of the replaced bearing (ground down to prevent press fit).
    • Place the spacer.
    • Let the spacer push on something, a large socket for instance, and center it on the press.
    • Press in the axle until the retaining ring groove is above the bearing (and the retaining ring can be put back).
knipwim
crwdns2935283:009/01/18crwdne2935283:0
13.715 crwdns2915208:0crwdne2915208:0
crwdns2935297:039crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 147
