Kinivo ZX100 Mini Portable Speaker Replacement
  1. Kinivo ZX100 Mini Portable Speaker Replacement, Disassembling Kinivo ZX100 Mini Portable Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
  2. Kinivo ZX100 Mini Portable Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kinivo ZX100 Mini Portable Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 12 mm Phillips screws from the enclosure.
  3. Kinivo ZX100 Mini Portable Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kinivo ZX100 Mini Portable Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
  4. Kinivo ZX100 Mini Portable Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
  5. Kinivo ZX100 Mini Portable Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder both wired connections.
    • Once the solder has melted, the wires should be easily pulled off the circuit board.
    • Be sure to connect the black wire to SPK- and the red wire to SPK+ when soldering the wires back onto the circuit board.
Test the speaker once you’ve reassembled it. Sound should now play properly on your Kinivo ZX100 Mini Portable Speaker.
Justin DaRosa
crwdns2935283:003/28/15crwdne2935283:0
146 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Shastany Spring 2015 crwdns2935289:0UMass Dartmouth, Team 1-5, Shastany Spring 2015crwdne2935289:0
UMASSD-SHASTANY-S15S1G5
crwdns2942667:0crwdne2942667:0 571
