This guide will cover how to remove and replace the bezel on a Kindle Touch and requires using a plastic opening tool and PH00 screwdriver.
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Slide the back panel downward, toward the charging port. This will release the clips on the top half.
Once the top clips release, gently lift the back panel away.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
Use the plastic opening tool to pry the bezel from the top and sides
I want to paint The bezel white. Will it come back and fit perfectly after the removal I have to make?
denianyc - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
