Kindle Touch Battery Replacement
  1. Kindle Touch Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Touch Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Touch Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
    Wear work gloves as the tool can easily slip and stab you in the hand.
    BRUCE - crwdns2934203:0crwdne2934203:0
    The clips aren't all the same; the side clips are slide-locks rather than press-locks.
    Use the Opening Tool to unclip the clips along the bottom edge. This will allow the lid to slide towards the top, releasing the side clips and allowing the lid to be lifted off.
    When reassembling, slide the lid upwards while pressing the sides to re-engage the side clips, then press the bottom edge to lock it into place.
    jimf - crwdns2934203:0crwdne2934203:0
  2. Kindle Touch Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Touch Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
    There are four tabs on each side.The two nearest the top are open at the top, hence they slide out (back towards the power connector end.
    This is important in the reassembly stage:
    1. Align the back cover about 0.75 cm away from the top
    2. Hold the top half of the cover flat against the unit, and flex the cover away from the case a little at the bottom
    3. Slide the top and the first two clips parallel to the case
    4. snap the remaining bottom clips in place
    John Haywood - crwdns2934203:0crwdne2934203:0
  3. Kindle Touch Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Touch Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Touch Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Touch Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Touch Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the flat end of your spudger, gently pry the battery up and remove it.
crwdns2935229:020crwdne2935229:0
Adam Yerly
crwdns2935283:001/20/15crwdne2935283:0
1.982 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 19-5, Blackwell Winter 2015 crwdns2935289:0USF Tampa, Team 19-5, Blackwell Winter 2015crwdne2935289:0
USFT-BLACKWELL-W15S19G5
crwdns2936753:030crwdne2936753:0 121
crwdns2942667:0crwdne2942667:0 11,523
