Amazon’s Kindle Paperwhite 3rd Generation (7th Generation of Kindles) possesses a 3.7 Volt, Lithium Polymer battery (Model No: MC-354775-05). This guide requires that the Kindle is turned off, and that a plastic opening tool, and a PH000 screwdriver are used.
Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
You want to make sure your separator goes through both sides of the bezel over top of the display.
The second photo is the layer you want your tool to pass through safely.
The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
Gently lift the mid-frame out of the case with your hands.
Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
Gently lift the battery from the frame.
crwdns2935229:095crwdne2935229:0
crwdns2947412:023crwdne2947412:0
Same for 5th Generation ??
PAUL FRIEND - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
where can i buy a new battery ?
david horn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
you need a taobao.
lol
kassadin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
They are sold on aliexpress and ebay but the price of battery and postage is not that different from the price of a second hand 3ed Gen Kindle. But then the second hand Kindle will probably need a new battery too so, I am going to get a battery from ebay.
Timothy Takemoto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
