Kindle Paperwhite (4th Gen) Screen Replacement
  1. Kindle Paperwhite (4th Gen) Screen Replacement, Remove the top case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the splungers, split the top case from the rest of the body.
    • The case is glued to the screen, optionally use a hair dryer or heat gun to soften the glue
  2. Kindle Paperwhite (4th Gen) Screen Replacement, Split the back case with the frame: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With a T5 Torx Screwdiver, unscrew the 10 screws holding the frame with the back case
    • After that, with the opening tool, split the back case from the main body
  3. Kindle Paperwhite (4th Gen) Screen Replacement, Disconnect the wires and remove the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the tweezers, disconnect the wires from the motherboard. Start with the battery and then remove the 3 connections from the screen
    • Unscrew 2 T5 Torx holding the motherboard to the frame
    • Remove the motherboard from the frame
    • (optionally) remove the battery from the frame
  4. Kindle Paperwhite (4th Gen) Screen Replacement, Remove the broken screen from the frame: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Paperwhite (4th Gen) Screen Replacement, Remove the broken screen from the frame: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • with the help of a heat gun or hairdryer and a razor blade, remove the screen from the frame (this step will take significant time)
    • After all the glass is fully removed from the frame, use alcohol or a dissolver to clean the remaining glue
  5. Kindle Paperwhite (4th Gen) Screen Replacement, Attach the new screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Attach the new screen to the frame
    • 1st, verify it fits well. Once that is done, remove the adhesive tape from the back of the screen and attach the screen to the frame - apply light pressure to fully glue it to the frame.
  6. Kindle Paperwhite (4th Gen) Screen Replacement, Re-wire the screen: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Put back the motherboard in the frame.
    • Place the motherboard in the plastic spacers provided. After it fits, screw the 2 T5 Torx holding the motherboard to the frame
    • Connect all wires to the motherboard (3 from the screen, 1 battery)
  7. Kindle Paperwhite (4th Gen) Screen Replacement, Re-assemble back: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Re-attach the frame with the back case, making sure it clicks and sits right in
    • Screw the 10 T5 Torx screws attaching the frame to the case
    • Finally, put in the front case and hold it tight together for the glue to apply.
    • (optionally) if there are places where the glue was removed, dissassemble again the top frame and add extra in the adhesive side of the top case.
Oriol Torrillas
crwdns2935283:010/02/23crwdne2935283:0
154 crwdns2915208:0crwdne2915208:0
Any suggestions to quicken the screen removal step? I've been trying to remove mine with the iOpener and a hair dryer, and it's taken me about 1h30min to remove 1/6 of the screen, and it's really tough still. Am I not heating it enough?
Edit: Step 4 to clarify
Simão Espanha - crwdns2934203:0crwdne2934203:0
I found a razor blade to be helpful. Metallic objects to pry, trying to get the screen lifted up/split from the glue.
Nevertheless, it was a long process for me as well. About 3-4 hours for the whole screen - it was really glued in
Oriol Torrillas -
crwdns2936753:07crwdne2936753:0 60
crwdns2936753:030crwdne2936753:0 242
crwdns2942667:0crwdne2942667:0 3,320
