Kindle Fire HD 10 Screen Replacement
  1. Kindle Fire HD 10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the case using the iFixit tool.
    • Make sure to go around the whole case before removing the whole case.
    7th gen Fires don't have a beveled back like in the photos. That looks like a 4th gen model. The 7th gen and newer have rounded edges and a flat back. The screen is glued to the chassis. You need to heat it up to about 65°C to soften the adhesive, and a suction cup to pull it away from the body to the tablet.
    Notary Sojac - crwdns2934203:0crwdne2934203:0
  2. Kindle Fire HD 10 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the casing, flip the tablet over so the screen is facing down.
    Can you be clearer about what you mean here? I also think you could combine this with the next step, and maybe mark up this image to show where the connector is.
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  3. Kindle Fire HD 10 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the ZIF connector that is attached to the screen carefully using an iFixit Jimmy tool.
    • Pull out the connector using the rubber tipped tweezers carefully.
    Proofread carefully for capitalization and end punctuation—this is the last time I’m marking these errors. How can I pry open the connector? What tool are you using here? How can I pull out the connector?
  4. Kindle Fire HD 10 Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Heat up an iOpener (or use a heatgun) and apply it along the edges of the screen.
    • Begin to pry open the edges of the screen carefully using an opening pick.
    • It may help to pry open the edges first.
    When you’re using tools, make sure to identify them. Check this throughout all guides.
  5. Kindle Fire HD 10 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Fire HD 10 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screen with your fingers.
crwdns2935229:09crwdne2935229:0
William Hess
crwdns2935283:010/11/19crwdne2935283:0
758 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S1-G5, Watkins Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S1-G5, Watkins Fall 2019crwdne2935289:0
ERAU-WATKINS-F19S1G5
crwdns2935297:011crwdne2935297:0
crwdns2947412:09crwdne2947412:0
hi, not sure whether this is the best spot to post this but i need help. so after replacing the lcd screen completely for a fire hd 10 7th gen. the new lcd screen displays nothing even though you can hear the tablet powering on and making noises. what could it be ?? thanks
Okai R - crwdns2934203:0crwdne2934203:0
My fire tablet needs an lcd screen replacement
Heri R - crwdns2934203:0crwdne2934203:0
I just completed this tutorial. I feel it is missing some important steps/tips.
STEP 1 - Pry open using a plastic pry tool. Do not be afraid to use a little force after you have gone around the edges since there are plastic clips in the middle of the back panel. DO NOT insert any pry tools deep inside to pry it open. You could damage some wiring or the motherboard itself. Just use your hand and don’t try to go to fast.
STEPS 2 is good
STEP 3 - DO NOT use a metal tools at any time during this step. Use a small plastic pry tool to lift up the BACK part of the ZIF connector until it is vertical. It should not take much force at all. Do not try to pull the flex out prior to this step or you will damage the flex and/or the socket. once the ZIF socket is unlocked (vertical), you should be able to pull the display flex out by hand - NO BIG OR FAST MOVEMENTS.
STEP 4 - if using heat gun, use low heat and heat evenly. heat up the flex a little before transferring.
STEP 5 - I used 2 sided tape to replace the stock adhesive
Michael Northness - crwdns2934203:0crwdne2934203:0
Never mind gorilla glass -- Amazon used gorilla glue all around the screen/digitizer. In an hour of alternate heatgun, razor, and pry tool work, I got one corner and about 10cm of one edge free. An Amazon-refurbished tablet goes for $60-$75; unless you value your time (and curses) very little, I can't recommend this project.
Monte Davis - crwdns2934203:0crwdne2934203:0
Where are the steps to actually replace the screen? I only see the steps to remove the screen
Amanda Wagner - crwdns2934203:0crwdne2934203:0
Pretty much put the screen back in after connecting the flex cable; make sure you an adhesive around the frame before installing the new screen of course, I have one today I am doing, ill probably use 1-2 sizes of Tessa tape when I do this.
Josh Lester -
I would absolutely NOT recommend you try this, unlike the ipads the screen an digitizer are very difficult to seperate, ipad was actually easier than this was. Save your money either take it to a repair shop or buy a new device. In my case the crack went through the screen an into the visualizer, it is almost expensive to buy a new screen as a new device. Best of luck.
Peter Frost - crwdns2934203:0crwdne2934203:0
Hey my iPad has a crack on it but it still works anyways I need a guide steps to fix it without replacing it I just got it today
Alyssa calvarese - crwdns2934203:0crwdne2934203:0
If there is no screen protector tape the whole screen with packing, duct or masking tape to hold any glass slivers. masking or duct can take hairdryer heat or better and retain the heat a bit longer.
If you bust up the edges and get glass still on after the screen is out heat up the tape and it will peel with the remaining glass.
My aftermarket screen did not have the backside half inch foam blocks so I removed the ones on the OEM screen.
Jason St Pierre - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 224
crwdns2942667:0crwdne2942667:0 22,210
