Kindle Fire HD 10 Battery Replacement
  1. Kindle Fire HD 10 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire HD 10 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the case using the iFixit opening tool. Make sure to go around the whole case before removing the whole case.
    • Some force is required to remove the back cover. In order to remove the casing successfully, keep the clips holding the cover from "popping" back in.
    I think you could combine these two bullets to be more concise. Can you be clearer about how to separate the two pieces?
    Alex Watkins - crwdns2934203:0crwdne2934203:0
    There are an additional 4 clips on the back of the 10 inch Fire that engage with catches, 2 on each side near the battery. Open case as described but to more easily separate slide a long spunger inside the case to disengage these inner clips from their catches.
    George Monk - crwdns2934203:0crwdne2934203:0
    Blue plastic spudger(?) broke off straight edge into little blue plastic pieces. Very hard to use without a straight edge to pry with.
    Glenda J. Bocskovits - crwdns2934203:0crwdne2934203:0
  2. Kindle Fire HD 10 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Fire HD 10 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic yellow taping from the wire circuits using a pair of tweezers.
    Where is this? Consider adding a top-down markup shot to show the user where this is. Do you have a less blurry image? Do you have images where you’re doing this, like a before and after?
  3. Kindle Fire HD 10 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With slight force pry off the cable connecter using a spudger.
    Which tool? Does it require force? Also, note that iFixit uses circles for screws, only.
    These are great questions! I can definitely imagine myself being a bit confused without some of the details you requested/suggested.
    Kudos, too, to the author(s) who incorporated the additional information into this VERY helpful tutorial. Your efforts are greatly appreciated!
    Hamartia MacGuffin -
    May want to let people know in which direction you need to go to "pry off" the cable end that attaches. Especially as the spudger in the image looks to be applying force toward the battery. For those that come later, you need to "pry up" from the cable side as there are two extrusions that lock the cable end from moving toward the battery.
    Morden Kain - crwdns2934203:0crwdne2934203:0
    Once you have pried it off, going in reverse directions (which is what I am told at end of guide to install new battery), how do you 'adhere' the cable connector to the back of the device again? I see a white painted on square and .. ... dots of metal at the top where the leads (2 red, 2 white, 2 black) touch, but how does someone 'connect' the two? hot glue? super glue? It does not stay secured there by itself.
  4. Kindle Fire HD 10 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Fire HD 10 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 4mm screws from the outsides of the battery with a Phillips #0 screwdriver.
    • Lift out the battery from its resting position using your fingers.
    Make sure to mark up all screws. You also don’t need the image with the screw measurement.
    What a pain in the ass. that battery is attached to the frame with strong double sided tape. Bent the frame all up removing the battery.
    Dexter Douglas - crwdns2934203:0crwdne2934203:0
    The battery is attched to the tray with double sided tape. I used an old credit card to get between the battery and the tray, starting at the corners, and worked my way around cutting the bond with the credit card. Its only attached at the two long outer sides of the battery. I then used two Iphone battery sticky strips, one on each side with the pull tab hanging out past the battery to resecure it. Worked good without too much tray distorion.
    fclmscott - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Jonathan Stewart
crwdns2935283:009/19/19crwdne2935283:0
394 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S1-G5, Watkins Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S1-G5, Watkins Fall 2019crwdne2935289:0
ERAU-WATKINS-F19S1G5
crwdns2935297:011crwdne2935297:0
crwdns2947412:05crwdne2947412:0
I cannot open a SL056ZE.
I mean I opened it up to all around it, it lifts but there seems to be part of ‘blue’ plastic cover - internally - that is kind of locked into right side of PCB [looking at it with battery below !
Any ideas?
JoeBlog - crwdns2934203:0crwdne2934203:0
Probably amazon locking it because of their stupid repair practices, Is it possible to rip it off or unscrew it somehow and reattach it? Get back to me if that is a possibility
Alyssa Bell - crwdns2934203:0crwdne2934203:0
Two problems I have found so far. The first one is that the cover has some clips on the inside so you have to play with the cover until you can get them to release. Be careful as too much pressure will crack the screen. The second problem is that the battery is glued to the metal frame that you just removed the 4mm T4 Torx screws. Something that should take a few minutes has taken me a few days just to make sure I don't destroy the screen.
thermalone - crwdns2934203:0crwdne2934203:0
An addition to my previous post: I had to use a plastic kitchen spatula in order to separated the battery from the metal tray. It has two glue strips that were reused to hold the new battery pack in place. The old battery pack was totally destroyed and will be properly recycled. Now it's a struggle to get the case to mate with the screen and lock in place. so far only one side has mated properly. will keep trying until its done correctly.
I was thinking my battery may need changing as slow charging, but after reading all these comments, I may just buy a new tablet! May be cheaper than going to a shop to ask them to do it and they need it up.
Kathleen Hill - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 81
crwdns2936753:030crwdne2936753:0 389
crwdns2942667:0crwdne2942667:0 25,341
