Kindle Fire Front Glass Panel Replacement
  1. Kindle Fire Front Glass Panel Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Back Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Where can I buy a battery for my kindle fire
    nannyto2 - crwdns2934203:0crwdne2934203:0
    Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
    vvenona1954 - crwdns2934203:0crwdne2934203:0
    Remember to remove any sd card first!!! Snapped mine in half.
    lucy_lady_bug - crwdns2934203:0crwdne2934203:0
    I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
    Kris Sanders - crwdns2934203:0crwdne2934203:0
  2. Kindle Fire Front Glass Panel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Mine has another plastic pc over the m.etal plate
    Keith Long - crwdns2934203:0crwdne2934203:0
  3. Kindle Fire Front Glass Panel Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
    • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  4. Kindle Fire Front Glass Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat the process from the previous step to free the left battery cell.
    The CPU got extremely hot and just now getting repaired 5 days or so
    Kelli Sabashion - crwdns2934203:0crwdne2934203:0
    I can't get the battery to charge
  5. Kindle Fire Front Glass Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
    • Pull the battery out of the Kindle Fire.
  6. Kindle Fire Front Glass Panel Replacement, Speaker Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Speaker Assembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Speaker Assembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the tape on the upper-left IC that is securing the speaker cable.
    • Use the flat end of a spudger to push the speaker connector out of its socket.
    • Deroute the speaker cable.
  7. Kindle Fire Front Glass Panel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 3.3 mm Phillips #00 screws securing the speakers to the Kindle Fire.
    • Lift the speakers out of the Kindle Fire.
  8. Kindle Fire Front Glass Panel Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Motherboard: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.3 mm Phillips #00 screws from the touchscreen controller.
    • Use a plastic opening tool to release the touchscreen controller connector.
    • Gently remove the touchscreen controller by lifting it up and to the right.
    • Be careful not to rip the ribbon cable in doing so.
  9. Kindle Fire Front Glass Panel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to flip open the power button ZIF connector.
    • This connector will not be removed until the motherboard is free.
    • Flip open the ambient light sensor ZIF socket with a plastic opening tool.
    • Use a pair of tweezers to pull the blue tab on the ambient light sensor cable to remove it from its socket.
    Make sure to mark what ZIF connector goes where, they are not interchangeable even though a first glance the appear to be the same size
    David Alvarez - crwdns2934203:0crwdne2934203:0
    It took about 2 hours, but that is, mainly, because reconnecting the ZIF connectors can be overly tedios.
    Apparently not all Kindle Fires have the ambient light sensor; This connector is not present on mine.
    diprosew - crwdns2934203:0crwdne2934203:0
    I cannot get the zif connectors to go back in ..what can i do...been trying for hours to get them back in...im talking bout the white flip pieces that lock in film..some one please help me with this!!
    bearangel246 - crwdns2934203:0crwdne2934203:0
    Stand it up on its end, lining up the holes to the wires. Slide into holes and 'flip'/rotate white plastic piece down into a flat position.
    toniamosley -
  10. Kindle Fire Front Glass Panel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to lift up and disconnect the display data cable.
    • Lift up on the antenna connector with a plastic opening tool to disconnect it.
    • De-route the antenna cable.
    Be very careful when disconnecting the antenna, and be sure to note how the cable is routed into the little socket on the motherboard. The reconnecting of the antenna cable into its motherboard port can be tricky and will require patience, persistence and perhaps a magnifier and tweezers.
    Jeff Jones - crwdns2934203:0crwdne2934203:0
    note that the image still displays the speakers that were supposed to be removed in an earlier step
    Followed the steps but once reassembled the screen comes on but doesn't respond to touch. It was working fine even with broken glass screen. Any suggestions?
    John Moore - crwdns2934203:0crwdne2934203:0
    Mine is doing the same thing! What did you do to fix it?
    Tara -
    I order a replacement motherboard from ifixit and for some reason it had a plastic increasing around the outer edge of the "display data cable connection port" on the motherboard, which makes it impossible to connect the cable to the motherboard. I called ifixit and they said send a picture and a description. Hopefully the customer who owns the kindle fire will understand that after waiting on the part for a week. :\
    nuban1990 - crwdns2934203:0crwdne2934203:0
    Mine no longer responded to touch!!!!! Why did we all have the same problem on reassembly after changing charging port?
    gregk8776 - crwdns2934203:0crwdne2934203:0
  11. Kindle Fire Front Glass Panel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 2.6 mm Phillips #00 screws securing the motherboard to the frame.
  12. Kindle Fire Front Glass Panel Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to gently lever up the bottom side of the motherboard to free from the adhesive on its underside.
    • Lever the top side of the motherboard up with a plastic opening tool until it comes free.
    • Lift the motherboard out of the Kindle Fire, making sure that the power button cable from step 8 comes free from its connector.
  13. Kindle Fire Front Glass Panel Replacement, Power Button Board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Power Button Board: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2.5 mm Phillips #00 scew securing the power button board to the Kindle Fire.
    • Lift the power button board out of the Kindle Fire.
  14. Kindle Fire Front Glass Panel Replacement, Frame Loosening: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Frame Loosening: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Frame Loosening: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to peel the ambient light sensor cable off of the frame.
    • You will need to peel up the silver tape in the cable's lower right bend. The silver tape under the lower left bend of the cable does not need to come up with it.
  15. Kindle Fire Front Glass Panel Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of a spudger to peel up the silver tape securing the antenna cable.
  16. Kindle Fire Front Glass Panel Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.6 mm Phillips #00 screws securing the frame and ambient light sensor.
  17. Kindle Fire Front Glass Panel Replacement, Ambient Light Sensor: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the ambient light sensor out from under the frame and remove it from the Kindle Fire.
    • If the ambient light sensor will not easily come out, slightly lift the frame with a plastic opening tool to allow it to come free.
  18. Kindle Fire Front Glass Panel Replacement, Frame: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Frame: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, Frame: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to lever the frame away from the display assembly until you can grab it with your hand.
    • Lift near the retaining tabs marked by red rectangles in the first picture.
    • Remove the frame from the display assembly.
    • While removing the frame there may be sticky residue that will generate some resistance to the detachment of the top half of the frame.
    I would have referred to the end with the USB Port and power button as the bottom end not the top.
    bdawson - crwdns2934203:0crwdne2934203:0
  19. Kindle Fire Front Glass Panel Replacement, LCD: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, LCD: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle Fire Front Glass Panel Replacement, LCD: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2.4 mm Phillips #00 screws attaching the LCD to the front glass panel.
    • Rotate the top of the LCD 90 degrees away from the front glass panel as shown in the second picture.
    • Rotate the LCD and front glass panel slowly so you don't damage the antenna on the bottom of the LCD.
    • Separate the LCD and front glass panel.
    Separate the front glass panel can be tricky, it's glue to the frame. Mine was cracked pretty badly so I won't come out in one neat little piece. Just patiently peel off the screen slowly.
    I attempted to separate the glass from the black screen/digitizer (LCD) and it was all glued. Kept heating the area probably 30 times. My glass has been cracked throughout and it was impossible to peel it off without damaging the screen/digitizer. Now the Kindle Fire HD is trash. I don't intend to spend nearly $100 for a replacement LCD, especially after I have already purchased a replacement front glass.
    Ron Tittle - crwdns2934203:0crwdne2934203:0
    Go on ebay I ordered my LCD there and it was 22.00 I replaced the clear digitized (22.00 also). If you still do not want to mess with it, list it for parts and take pictures and post and it will sell trust me.
    Cynthia -
    FYI you may want to change the bit size to a PH000 for the PH00 is a bit to big and you may risk the chance of damaging the screw and you may never get it out then! just a heads up for you guys!!
    Tysl332 - crwdns2934203:0crwdne2934203:0
crwdns2935229:085crwdne2935229:0
Phillip Takahashi
crwdns2935283:008/22/11crwdne2935283:0
87,414 crwdns2915208:0crwdne2915208:0
crwdns2935297:087crwdne2935297:0
crwdns2947412:025crwdne2947412:0
How does that tell you how to fix the screen you are just putting the screen on so it sill cracked so how are you going to fix it now?
Morgan Gregory -
This took me about an hour from start to finish - taking my time to mark all the screws etc. but it may take longer if you don't have the correct tools. I agree that there should be a photo of separating the front glass digitizer from the front bezel as the true last step - it can be tricky, and the replacements I have seen don't include the front bezel. I used a razor/hobby knife to slowly peel and separate the digitizer working slowly and carefully from the inside bottom (around and behind the power button cutout) - some goo-gone or lighter fluid will be necessary to clean any old adhesive residue from the bezel as well. The front bezel has a rubberized gasket that should not be remover, so take care to see that you are not peeling that off. My last suggestion is to wear latex or nitrile gloves to prevent getting smudges on the LCD or digitizer during replacement; put them on for step 18, and until you have the frame back in place - care to keep dust out from in between during reassembly is a must!
revere521 - crwdns2934203:0crwdne2934203:0
I agree this was difficult, I used 3 different explanations/videos and this was the easiest to follow due to still frame. Thanks for sharing. It took longer than I expected but I did it
kasey - crwdns2934203:0crwdne2934203:0
How do I know which part I need?? Do I need the lcd screen and/or the digitizer?? What's the difference?? My kindle was dropped unfortunately and I am trying to find the part to replace it with. PLEASE HELP!! People are trying to charge me 100$ to replace the screen alone, excluding labor.
stefani - crwdns2934203:0crwdne2934203:0
is the mother board cable available to order? mine tore!
JODY - crwdns2934203:0crwdne2934203:0
Took me two hours but worked great - my daughter will be very happy in the morning. The hardest part of replacing the broken front glass was separating the broken glass from the plastic front housing as there was no instruction for this. As another person noted, I, too, used an X-ACTO to separate the two. During dis-assembly, I kept track of the screws as I removed them which made it easy to put them back. Good Luck and thanks to the Original Poster and all the other help here. (I didn't need to search elsewhere - this was all inclusive for me). Again, Thanks!!!
Paul Borgmeier - crwdns2934203:0crwdne2934203:0
Excellent guide! Works perfectly now. Get the correct tools and take your time.
Sean Agard - crwdns2934203:0crwdne2934203:0
Extra details were needed at Steps 3 & 4! The text implies it's lightly glued on the edges of the battery. NOT SO! It isn't 'tacked' down into the frame, it's held quite nastily by a piece of doubleback right in the center. I broke the large plastic lifter I had, and after 30 mins of working with the smaller one, and finally lifted the battery, I found I had damaged the "ambient light sensor cable". So I've now got a piece of junk. I figure the rest of this procedure is void of other key details, so I'm done. Until they figure out how to make Lexan screens (virtually an indestructible material as opposed to glass which shatters if you look at it wrong), I'm pretty much out of this tablet game, which should come with a orange "Chance" card reading: "You bumped your kindle against something more firm than a pillow. Do Not Pass GO, Do not Collect $200, instead donate $100 to the tablet repair geeks, or simply thrown that marvel in the trash and pay for another one. You just made Jeff Bezos richer."
Adam Troy - crwdns2934203:0crwdne2934203:0
The Capacitive Sense only works with glass. The resistive screens wear out after some use.
Keith -
Well I am a 53 year old retired Sailor that has big fat fingers... I gotta say I did the whole thing in about 1 1/2 hours and have no experience with electronics. I did have a couple problems with the little flip up white plug thingies... but even after the fight with them my Kindle Fire works like a champ. Thank you so much you saved me alot of $$ that I do not have on my fixed income. I promise to come back if I have problems with any of my fancy electronic thingies! @-->-- My hats off to all of you at IFIXIT.COM! Oh I have an extra screw... is that a bad thing?? LOL
Howard Hammond - crwdns2934203:0crwdne2934203:0
I have twin grand kids, wanted to give them each Kindles. I bought 2 that had cracked screens but functional. Through trial and error I learned. I watch a couple videos on you-tube. I knew I could do this and I did. My first attempt removing the top glass digitized scree broke the LCD. I had to then order and wait for arrival to finish and during my wait I watched several more videos. It arrived and I successfully put it back together, working like new. The second one I knew to use something at each point where I was carefully separating the top glass. So you know all those credit card applications you get in the mail? They are fake plastic cards and they slide "carefully" just under the glass edge making it so much easier to remove it. Be very careful when replacing the screen not to tear the ribbon thing that is on the screen or you will need another one. If you want you could tape yourself as you tear it down to replay to see where each part goes back to.Once you have done a couple you get better at it
Cynthia - crwdns2934203:0crwdne2934203:0
Perfect Guide, glass was shattered due to a fall on concrete. I just followed the steps. Succes !
Peter - crwdns2934203:0crwdne2934203:0
This was absolutely wonderful instruction. Great detail. For separating the glass at the end, just warm the frame around the seam where the glass is glued down with a hair dryer on hot setting and use metal tool to pry around (see you tube videos ) you may have to re-heat if it takes a while. Couldn't have done it without these great instructions. Saved me 200.00. Thanks!
toniamosley - crwdns2934203:0crwdne2934203:0
Will removing the motherboard remove all of the memory on the tablet?
nitisss - crwdns2934203:0crwdne2934203:0
To revise a reply I made quite a few years ago:
Removing the motherboard will not erase the data, but keep in mind that the data is stored on a chip on the motherboard. If you replace the motherboard, your data will still be on the old chip; it will, in effect, be erased.
[deleted] -
My Aunt's kindle fire HD has been afflicted with the frozen screen/non-responsive screen bug that seems to be so common amongst this particular model. Amazon suggested a hard reset, but it didn't work. My question is, will replacing the digitizer fix this problem? Or will it return even after if I have replaced said digitizer. Thanks!
DarkWingDuck - crwdns2934203:0crwdne2934203:0
Correction, meant "My Aunt's kindle fire 7", 2011 model"
I'll agree that my battery felt like it was glued in with superglue. It took forever to get out and, in the process, I put a hole in the silver bag around the battery. I assume it's not safe anymore. Is it able to be patched up with electrical tape? I'm going to continue replacing the glass to get practice whatever the answer, but there was one thing I was confused about. Some tutorials say you don't need to remove the motherboard and speakers, etc..., just the digitizer. Is that possible? (Some videos gave the impression they were showing the removal of other parts as an "FYI", not necessity.)
saletales - crwdns2934203:0crwdne2934203:0
How can I tell if I have a first or second generation Kindle fire 7? Screen is broken and I originally received it as a gift without any packaging.
Clay Briggs - crwdns2934203:0crwdne2934203:0
What about the Amazon Kindle Fire Model SG98EG. I know how to separate the front from back. But your instructions to not cover that. Would you direct me to one that covers this Model?
Lance.R.Violator@Gmail.com
Lance Violator - crwdns2934203:0crwdne2934203:0
My granddaughter dropped her Kindle and the glass was shattered. Successfully removed the glass and all fragments BUT IN THE PROCESS ALL OF THE DOUBLE SIDED 3M TAPE IS GONE.
Where do I purchase new tape strips?
The new glass/screen I purchased seems to have a tiny strip of foam all around that the original glass/screen did not have. I thought this might be the tape strip but apparently it is not.
Help!!
karen - crwdns2934203:0crwdne2934203:0
Help….I have removed the glass and because it was so shattered all of the double sided tape is also removed.
The new screen/glass does not have any tape.
Where can I purchase the tape and view a video to help?
I replaced the cracked screen and it turns on but the touch screen doesn't work now. How do I fix that? TIA
Ricco Feudo - crwdns2934203:0crwdne2934203:0
After step 19, How do you remove the screen from the frame?
Hunter Stone - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 225,774
