Remove the back case from your Kindle Fire to access its internal components.
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
crwdns2935229:014crwdne2935229:0
Simple to follow instructions .
Eric Rester - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
where to buy the base panel for my kindle fire 7 tablet
Senthilvel Murugesan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I was wondering why my kindle case was opening/separating and it was not charging. I opened the case per you instructions and found that the battery has expanded inside ITS case! I hope to be able to get another battery cheaply. Thank you for your help!!
Ellen De - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
