Kindle 4 Motherboard Replacement
  1. Kindle 4 Motherboard Replacement, Open front and back covers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle 4 Motherboard Replacement, Open front and back covers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle 4 Motherboard Replacement, Open front and back covers: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the Screen Replacement tutorial up to Step 4
    • Open the back cover
    • Remove the front cover
    • Disconnect the battery
  2. Kindle 4 Motherboard Replacement, Disconnect cables: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect all flex cables from the board
    • There are 4 connectors to unclip:
    • Right buttons
    • Left buttons
    • Screen
    • Battery
  3. Kindle 4 Motherboard Replacement, Unscrew the board from the back: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the board from the back
    • 3 Torx screws on this side
  4. Kindle 4 Motherboard Replacement, Unscrew plastic casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the plastic casing from the front
    • 2 screws
  5. Kindle 4 Motherboard Replacement, Pop the plastic casing off: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 4 Motherboard Replacement, Pop the plastic casing off: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat the plastic piece to help unglue it
    • Turn the device and push the piece out through the casing
  6. Kindle 4 Motherboard Replacement, Unscrew board from the front: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew board from the front side
    • That’s another set of 2 screws !
  7. Kindle 4 Motherboard Replacement, Remove the board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kindle 4 Motherboard Replacement, Remove the board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kindle 4 Motherboard Replacement, Remove the board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The board has no more screws left, but it is still glued to the casing
    • Use some more heat to weaken the glue
    • Lever the board to unglue
    • Then, remove it by sliding it out
  8. Kindle 4 Motherboard Replacement, Taking a peek at the board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kindle 4 Motherboard Replacement, Taking a peek at the board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here is what it looks like with EMC shields removed
    • Don’t try to remove the shields on your new board, they are directly soldered, and you risk damaging the whole PCB.
  9. Kindle 4 Motherboard Replacement, Change the board and test: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you have another device from which you extract the new motherboard, run steps 1 to 7 again
    • Place the new motherboard
    • Before closing it back, test the device
    • Replug all connectors, connect the battery last
    • The LED should blink green upon battery reconnexion
    • Try turning the device on
  10. Kindle 4 Motherboard Replacement, Reassemble: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery again
    • Rescrew the board
    • Replug the battery
    • Reassemble the plastic piece holding the buttons, the front cover, and the back cover
Amazon apparently discontinued service for this model: the service will expect double authentication, which apparently is not implemented in the Kindle firmware.
However, you can still use your Kindle 4 with USB : it is recognized as mass storage, and you can load ebooks in PDF or MOBI format in memory.
Check out the open-source software Caliber to convert your files in a vintage Kindle-friendly format.
Eve Redero
crwdns2935283:002/28/22crwdne2935283:0
2.945 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 67
crwdns2942667:0crwdne2942667:0 2,156
