If you discover any issues such as quickly draining battery, freezing, overheating, or charging problems, this could indicate that you need to replace your battery. Through using this guide, you can learn the proper way to conduct a battery replacement for the Kindle 10.
Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
Use the metal spudger to gently lift the screen out of the back frame.
Detach the battery connector from the motherboard.
Do you have any replacements if we break the case ?
Calixte Marbach - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The affiliate-linked battery is incorrect. Don’t make the mistake I made. Do not purchase it.
dj TA630 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
@djta630 I just found this out the hard way as well. Fortunately, it’s only a few bucks, but definitely frustrating.
kennethbaese - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
