Replacing the mop pad on your Kilgone G20 is a simple yet essential maintenance task to keep your device performing at its best. Over time, mop pads can wear out or accumulate dirt that’s tough to clean, reducing cleaning efficiency. This guide will walk you through the steps to swap out the old pad for a fresh one, ensuring your floors stay spotless with every use. Let’s get started!
Flip the Kilgone G20 upside-down so the blue mop pad is visible.
Lift up the on the edge of the blue mop pad.
Remove it from the G20.
Flip the mop pad over so that the pad is facing down.
Peel the white cloth away, so that it's no longer hugging the plastic.
Flip the plastic around, and simply peel the mop pad off of the velcro.
