Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly
  1. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the USB/Power Off Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the USB/Power Off Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the keyboard and toggle the leftmost switch to the 'Off" Position
    • For reference, the switches are located on the top of the keyboard.
  2. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove Keycaps: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a keycap puller, carefully remove the keys from the keyboard
    • NEVER attempt to remove the keyboard keys on any keyboard without a keycap puller or tool specialized to remove keyboard keys, not using the correct tool may damage the keys
  3. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Confirm switches are hot-swappable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Confirm switches are hot-swappable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check that your switches are hot-swappable. If they are not, trying to remove them will damage your keyboard.
    • The mechanical switches are NOT hot-swappable, and the colored stem is smaller and more oblong.
    • The optical switches are hot-swappable, and they have a larger colored stem which is mostly square.
    Is having non-hotswappable keys means we cant disassemble it?
    Hasan Gülşen - crwdns2934203:0crwdne2934203:0
  4. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Removal of Switches: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a switch puller to remove the switches.
    • If you have the included switch puller from Keychrone, it may be tough removing said switches.
    • Each switch has small tabs on the corners to grab and remove them. (The Included switch puller might require extra strength to remove)
    BEWARE!!! My Keychron K3 looks exactly like this but the switches are soldered on!! If you just pull (like I did) you’ll break them!
    trevorsklar - crwdns2934203:0crwdne2934203:0
    The optical switches (pictured) are hot-swappable, and the colored part of the switch is approximately square. The mechanical switches are NOT hot-swappable, and the colored part is smaller and oblong.
  5. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the Chassis Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a # 1 philips drill bit to remove the 4 screws on the keyboard
  6. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Separate the Base and Top: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or another wedge tool to pry open the plastic base from the aluminum chassis.
    • Use caution when removing the base from the chassis as there are tabs that hold them together!
    • CAUTION: The battery is located on the plastic bottom. The battery is connected to the PCB located near the orange switches and USB
  7. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnect the Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disconnect the Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to disconnect the battery from the PCB.
    • Use caution when removing the PCB! Pull away from the connector. Do not attempt to jiggle the cable as this may loosen/damage the connector
    What is the part number or specs for the battery?
    Wendy Tang - crwdns2934203:0crwdne2934203:0
    Hi Wendy!
    I could not find an OEM replacement for the battery, but I did find a battery that a user used in a DIY project with this keyboard. It is not the same one used typically, but this one was reported to give 2x the battery life compared to the OEM one
    Pookie -
    Hi Tech Guy! The Ebay link is no longer working. Do you still remember the battery model?
    Yu Lu - crwdns2934203:0crwdne2934203:0
    Hi! This is the "Tech Guy" I did change my username. I do apologize for the broken link. I did find two replacement links and will add specifications for the battery in terms of size, milliamp hours, and voltage
    Amazon Aliexpress
    Dimensions (mm): 130mm x 32mm x 3mm
    Mah: 1600mAh
    Pookie -
  8. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Remove the PCB: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 14 screws with a # 1 Philips screw driver bit
    • To remove the PCB from the aluminum frame, use a spudger to wedge it out.
  9. Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disassembly complete: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keychron K3 Ultra-slim Wireless Mechanical Keyboard Disassembly, Disassembly complete: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The PCB is now removed and able to work on.
    • When you reassemble the keyboard, make sure to put the orange toggles with the two nubs pointing towards the switch side of the aluminum frame.
Mike Villasenor
crwdns2935283:005/04/20crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
Feel free to leave advice if you think I should change any steps. This is my first guide. Enjoy!
Mike Villasenor - crwdns2934203:0crwdne2934203:0
Hi Mike,
Great job! Check out this article on creating guides–it has some great tips! Looking forward to reading your next one!
Amber Taus -
Do you know what size screws the keyboard uses?
Sam Jackson - crwdns2934203:0crwdne2934203:0
Does anyone know where I can get a replacement battery for this keyboard?
Rakshak Raghavan - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 179
crwdns2942667:0crwdne2942667:0 9,571
