Keurig Mini B-31 K-cup Holder Replacement
  1. Keurig Mini B-31 K-cup Holder Replacement, K-cup holder: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the handle of the Keurig Mini.
  2. Keurig Mini B-31 K-cup Holder Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig Mini B-31 K-cup Holder Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
    • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
    You may want to show a picture of the needles to show what exactly to avoid even though it might be blatantly obvious.
    Creed Borden - crwdns2934203:0crwdne2934203:0
    You should write "They" between "inside the K-cup because" and "may puncture your hand"
    I did the needle up the 2 pin hole trick and it's working now!
    hooyame2002 - crwdns2934203:0crwdne2934203:0
    What is a needle up the 2 pin hole trick?
    Gina -
  3. Keurig Mini B-31 K-cup Holder Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig Mini B-31 K-cup Holder Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
  4. Keurig Mini B-31 K-cup Holder Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the K-cup holder straight out.
Andrew Adriance
crwdns2935283:001/14/14crwdne2935283:0
1,914 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-1, Forte Winter 2014 crwdns2935289:0Cal Poly, Team 17-1, Forte Winter 2014crwdne2935289:0
CPSU-FORTE-W14S17G1
Press up on the outlet of the holder to push it out. This is covered in the manufacturer’s user manual which comes with the unit when new.
jastpeel - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 13,081
