Keurig K55 Lid Spring Replacement
  1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K55 Lid Spring Replacement, Secondary Water Pump: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K55 Lid Spring Replacement, Secondary Water Pump: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the silver handle up.
    • Locate the screw and washer holding the handle in place on each side.
    • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
  2. Keurig K55 Lid Spring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K55 Lid Spring Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the handle and pull it upward and toward the rear of the device.
    • Lift the lid to the fully open position.
    • Remove the two 11mm Phillips screws located on the upper part of the device.
    • Be careful removing the screws; the needle here may be sharp.
  3. Keurig K55 Lid Spring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K55 Lid Spring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K55 Lid Spring Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lower the lid to just before its closing position.
    • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
    • Gently pull the top cover upward and toward the front of the device to remove it.
  4. Keurig K55 Lid Spring Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K55 Lid Spring Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K55 Lid Spring Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 11mm Phillips head screws securing the water pump.
    • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
    • Pull the other line from the water pump.
  5. Keurig K55 Lid Spring Replacement, Lid Spring: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K55 Lid Spring Replacement, Lid Spring: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the spring off the front hook using two fingers.
    • The spring has a lot of tension, so grip the spring end tightly.
  6. Keurig K55 Lid Spring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K55 Lid Spring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the spring off the other hook.
William O'Brien
crwdns2935283:001/23/18crwdne2935283:0
500 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S1-G3, Livingston Winter 2018 crwdns2935289:0Cal Poly, Team S1-G3, Livingston Winter 2018crwdne2935289:0
CPSU-LIVINGSTON-W18S1G3
What is the small plastic/rubber angled water line part that the front part of the water pump valve is inserted into ?
Joe K - crwdns2934203:0crwdne2934203:0
Well i might have described it as a water pump in my above message, but from what I've read on here it is a check valve, so what is the rubber/plastic small angled water line part that the front of the check valve is inserted into !
crwdns2942667:0crwdne2942667:0 1,980
