Keurig K40 Bottom Water Filter Replacement
  1. Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K40 Bottom Water Filter Replacement, Bottom Water Filter: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device on its side so that the metal faces you.
    • Begin by unscrewing the five 1.5mm bottom screws with a #0 phillips head screwdriver.
  2. Keurig K40 Bottom Water Filter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K40 Bottom Water Filter Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the base is unscrewed, remove the base from the plastic wedges used to hold it in place.
    • The wires do not need to be cut as this repair will not harm or use them.
  3. Keurig K40 Bottom Water Filter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K40 Bottom Water Filter Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a size 0 Philips head screwdriver, remove two 1.2mm screws that hold the filter in place.
    • Pull the pump back to remove it from the slot it was in.
  4. Keurig K40 Bottom Water Filter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip where the filter and the flow line connect and pull apart until they are separated.
    • Clean or obtain a new filter and put back together. This is done by repeating the steps in reverse, putting the device back together.
crwdns2935229:012crwdne2935229:0
jonathan
crwdns2935283:002/08/16crwdne2935283:0
738 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-1, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 6-1, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S6G1
crwdns2944067:013crwdne2944067:0
Where do you obtain a new filter?
Anthony Montoya - crwdns2934203:0crwdne2934203:0
I have the same question as Anthony. Every Keurig filter I see is the charcoal filter that takes 2 seconds to change
Matt Baum - crwdns2934203:0crwdne2934203:0
[|i have the same question as well.. I don’t see anywhere selling a new filter…]
eddie mayfield - crwdns2934203:0crwdne2934203:0
I need the filter, where do I buy a new Filter?
Gladys Karina Andino - crwdns2934203:0crwdne2934203:0
The answer seems to be: “You don’t.”
Van Davis - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 140
crwdns2942667:0crwdne2942667:0 34,467
