In this guide we will show you how to successfully remove the K-cup holder.
Press on tab while pulling up on K-cup until you hear a click. Repeat for the remaining tabs. We found using the smallest of the "plastic opening tools" worked wonders.
Once all of the tabs have been pressed, the K-Cup should just pop out. After, you just pull the remainder of the K-Cup. You have successfully removed the K-Cup.
I accidentally removed the k cup holder while wiping it out. Now I have the holder plus 3 small plastic and 1 rubber circular pieces. How do I put it back together again? I have the same Kuerig mini as pictured here.
