Keurig K10 MINI PLUS Handle Replacement
  1. Keurig K10 MINI PLUS Handle Replacement, Top Needle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K10 MINI PLUS Handle Replacement, Top Needle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 9 mm Phillips #1 screws.
    • Avoid the top needle if at all possible. The needle may cut you and/or penetrate your skin.
    • The screws are located on the top of where the K-Cup would be.
  2. Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you remove the screws, the top cover should come out.
    • The back of the cover is held in place by two locking tabs. To remove the cover, pull it back slightly and it should come free.
    • You will then want to remove these screws which are the same size.
    • The needle is sharp, so be careful.
  3. Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you get those removed, you are going to want to pull on the hose until it pops off.
    • Once the hose comes off, the needle will fall out by itself.
    • Be careful when picking up the needle as the needle is sharp.
  4. Keurig K10 MINI PLUS Handle Replacement, Handle: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #1 screws.
    • The top needle is intact and there, so be careful when in this area.
  5. Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Next, after the removal of the hose on the top by simply pulling it off, remove the following four Phillips #1 screws.
  6. Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you take off the screws, this part of the handle will come off.
  7. Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To pull this part off, pull inwards with the these tabs located on both sides of the handle assembly.
  8. Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame.
    • For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other.
    • Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
  9. Keurig K10 MINI PLUS Handle Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you pull both sides, the handle will come off as shown.
Roberto Maldonado
crwdns2935283:002/04/16crwdne2935283:0
395 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 2,622
