In this guide, we’ll walk you through the process of replacing the back panels of a Keurig K-Duo in the case that the plastic panel has been broken, faded out, or you simply just want to access other components.
Turn the Keurig K-Duo upside down so the power cord is visible and facing you.
Use a Phillips screwdriver to remove all four screws that secure the plastic panel.
To remove the back panels, grip each side firmly.
Gently pull the panel outward toward yourself to release and fully detach the plastic hooks.
