K-Cup pack holder is stuck?
This guide will show you how to remove and replace the K-Cup Portion Pack Holder for the Keurig B70 Platinum if you're experiencing any problems with the pack holder. Before continuing with the guide, you're going to need a Phillips #2 screwdriver.
Turn off and unplug the Keurig before starting.
Open the lid and remove the two 11.0 mm screws located below the K-Cup holder.
Pull the black plastic guard of the K-Cup housing away from the Keurig.
Push the black button at the bottom of the lid to remove the K-cup holder assembly.
From the top, lift the assembly out of the Keurig.
Grab the top and the bottom of the holder assembly and pull it apart.
Spring flew out as I was removing cup holder. Where does it go. How do I reinsert it?
