In this guide, you will replace the LCD screen. This is necessary if the screen is faulty and does not display information properly.
Open the K-Cup Chamber Housing Lid by lifting up the silver handle below the LCD screen.
Place the Keurig on its side.
Remove the two 140mm screws located on the underside of the Chamber Lid using the Phillips #1 screwdriver.
Remove the top black housing that surrounds the screen.
Using the Phillips #1 screwdriver, remove the two 140mm screws connecting the silver handle to the top of the Keurig.
These may be #2 Phillips screws, so if a #1 bit doesn't feel right try a #2.
Pull out the front silver handle from the top of the brewer.
Using the metal spudger, pry open the snaps holding the LCD screen panel to the brewer, just enough for the panel to pop loose.
Remove the top black housing by lifting it up.
Remove the black latch with the black wire connecting the front end of the panel to the frame.
On the bottom of the panel, remove the white tab that connects the wires of the circuit board to the LCD screen
To remove the tab, squeeze in on the sides of it as you pull it out.
Remove the touch screen panel from your device.
Where can I buy the replacement LCD screen please?
Where can I purchase the replacement LCD screen?
crwdns2935229:05crwdne2935229:0
Hello Alec,
Thank you for providing this repair guide! Could you kindly provide the screen size and where one might be able to purchase one? It would be greatly appreciated.
Regards.
Yes love the demo, now where would one find the screen to replace. Keurig states these are no longer available.
Try eBay. I saw one there.
I saw one on eBay.
