Kenwood KDC-BT565U Fuse Replacement
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kenwood KDC-BT565U Fuse Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
    What if the fuse melted inside
    Merlin Davids - crwdns2934203:0crwdne2934203:0
To reassemble, follow these instructions in reverse order.
Darren Evans
crwdns2935283:002/15/17crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G5, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team S2-G5, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S2G5
crwdns2935297:011crwdne2935297:0
crwdns2947412:07crwdne2947412:0
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - crwdns2934203:0crwdne2934203:0
it does not explain how to pull the reciever out.
d_lalande - crwdns2934203:0crwdne2934203:0
same problem, how to remove the receiver
Jason Armondo - crwdns2934203:0crwdne2934203:0
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - crwdns2934203:0crwdne2934203:0
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
Did you ever find problem on radio that didn't have power. I have same problem? Please share with me
Jannie watkins -
ATM fuses do not work, I think it needs to be an ATS and I am having difficulty finding ATS anywhere. ATS was the fuse that I took out of it so that is how I know.
CyberCheese - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 132
crwdns2942667:0crwdne2942667:0 23,522
