A blown fuse can render the KDC-BT565U unusable. Replacing of a dead fuse with a proper 10 amp car fuse can restore the unit to working condition. This guide shows you how to replace this fuse.
NOTE: This requires the KDC-BT565U unit to be unmounted from the car. This may require specialist assistance.
The fuse can be found on the back of your radio indicated by the red square in the photo.
Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
To reassemble, follow these instructions in reverse order.
crwdns2947412:07crwdne2947412:0
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
it does not explain how to pull the reciever out.
same problem, how to remove the receiver
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Did you ever find problem on radio that didn't have power. I have same problem? Please share with me
ATM fuses do not work, I think it needs to be an ATS and I am having difficulty finding ATS anywhere. ATS was the fuse that I took out of it so that is how I know.
