Kenwood KDC-BT565U CD Drive Replacement
  1. Kenwood KDC-BT565U CD Drive Replacement, Face Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press the eject button on the bottom left corner of the face plate.
  2. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by slightly lifting the face plate out from the side located by the release button.
    • Slide towards the side of the eject button, then completely lift out.
  3. Kenwood KDC-BT565U CD Drive Replacement, Metal Sleeve: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement, Metal Sleeve: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the outer metal sleeve with one hand and the front of the unit with the other.
    • Slide the sleeve back until it comes off the unit.
  4. Kenwood KDC-BT565U CD Drive Replacement, CD Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the thin frame from the front of the device. This can be done by first unsnapping the top pegs and then the bottom ones.
  5. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the clasps of the tabs around the edges by using a plastic opening tool or spudger.
  6. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5.5mm Phillips #0 (PH0) screws on the bottom of the unit.
  7. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 6mm Phillips #0 screws from the side of the unit.
  8. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7.5mm Phillips #0 screw in between the red and white RCA inputs.
    • Remove the two 13.5mm Phillips #0 screws towards the top of the aluminum block.
    • Remove the 10mm Phillips #0 screw towards the bottom of the aluminum block.
    • Remove the two 6mm Phillips #0 screws found above the microphone mount and below the circular port.
    • Remove the 7.5mm Phillips #0 screw next to the large rectangular power connector.
    • Remove the 10mm Phillips #0 screw that resides above the aluminum block.
  9. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the top and bottom metal housings of the unit carefully.
    • There is a connecting ribbon that links the two halves. Too much force could rip and irreversibly damage the ribbon.
  10. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the ribbon out of the connector found on the bottom half of the unit (the bottom half has the CD drive).
    • To remove the ribbon, grip the black base connector with one hand and the base of the ribbon with the other. The ribbon will have a blue, reinforced section close to the base (seen in second picture) which makes it easier to pull.
  11. Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenwood KDC-BT565U CD Drive Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • To fully unmount and replace the CD drive, remove the three 6mm Phllips #0 screws that hold the drive to the housing.
To reassemble your device, follow these instructions in reverse order. Be careful when reattaching the new CD drive's ribbon to the motherboard. The ribbon can be bent easily.
Connor Finley
crwdns2935283:002/18/17crwdne2935283:0
857 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S2-G5, Lacy Spring 2017 crwdns2935289:0USF Tampa, Team S2-G5, Lacy Spring 2017crwdne2935289:0
USFT-LACY-S17S2G5
crwdns2935297:011crwdne2935297:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 614
