If your Kenwood DNX571HD car stereo is having difficulty connecting to AM/FM radio, the radio antenna connection may be faulty. Follow this guide to replace it.
Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
Pull the top of the front panel out and down to remove front panel.
Unscrew the three 5mm screws from the top of the device using a Phillips #1 screwdriver.
Lift up to remove the top casing.
Flip up the black clasp with a spudger to disconnect the large white ribbon cable connecting the CD drive to the board underneath.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully unplug the fan power cord with the tweezers.
Unscrew the three 5mm length screws with the Phillips #1 screwdriver.
Remove the metal plate
Unscrew the three 5.5mm long screws with a Phillips #1 screwdriver.
Remove the four 5.5mm screws with the Phillips #1 screwdriver.
Lift the top part of the unit up from the lower chassis.
Remove the two 13mm long screws with a Phillips #1 screwdriver.
Desolder and remove the radio antenna from the motherboard.
