Disassembling the gearbox to replace the SER1018 planetary gearbox
Pull off the button
Remove the white rubber grommet
Loosen the 6-point nut
Pull the planetary gear straight out
Loosen the Torx screws that hold the bottom of the case
Remove the bottom case
The rubber gasket can be removed for cleaning
Remove felt mat
Remove the Phillips screws to remove both plastic parts
The plastic parts are different
The screws are Imperial not Metric
Remove the three torx screws
Lift off the housing cover
Pay attention to the white rubber buffer (red square)
If the plastic drive wheel was removed in the above step, the next step can be skipped.
Loosening the Tx20 screw hidden by the plastic drive wheel is challenging
I was not able to pull off the plastic drive wheel
If you want to take a chance, you can drill a hole in the plastic drive wheel. However, I did not have the courage to do so.
I made myself a special tool -> see next step
I machined a 6mm open end wrench to be form fit with the Tx20 bit
A slot has been cut in the screw for easier re-assembly
Remove guides (marked in red). They can be used after closing the case.
Remove seal. Has been replaced with silicone sealant.
The one with the cross drive is the old one
The new one has a bayonet lock. However, the whisks and kneading hooks are in the same position, opposite of the mixing bowl.
Difference in gear thickness doesn't seem to have an effect on the function.
Cod. SER1018: Label from the plastic bag containing the three spare parts
Planetary gear label
6-point nut: label and part
Push each gear on its axis
Be careful with the spacers
There is a lot of grease in the housing. Grease all the parts to be well lubricated.
Replace seal. See step 8.
Stand the machine upright on its feet and place the arm in the horizontal position. With the arm raised, the shaft falls out from the slow drive.
Gently push the parts together.
When disassembling, the screws were loose. That's why they were secured with a drop of screw lock.
Introduce the guides into the right places
Insert hidden screw
Tighten with the special tool from step 7
Continue from step 6 in reverse order to reassemble the device.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:010crwdne2947412:0
Hallo , sehr tolle Anleitung!! Meine Frage - nach dem Tausch des kompletten Getriebes (keine Einzelteile wie Zahnräder und dergleichen) wird das Getriebe nach ca. 10 -15 min. Knetarbeit sehr sehr heiß! Man kann sich eigentlich daran Verbrennungen zuziehen. Was kann da die Ursache sein??
Vielleicht hast du eine Idee dafür?
Lg Heinz
Hallo Heinz
Folgendes fällt mir zu der Frage ein:
- Das Getriebe sollte leichtgängig sein wenn man am Kunststoffzahnrad dreht. (Ohne Zahnriemen)
- Ist das eingesetzte Getriebe geschmiert? Roter Zapfen beim 5. Schritt
Gruss Bruno
Hallo Bruno,
das ist ja eine geniale Anleitung - KOMPLIMENT!
Bevor ich das Gerät zerlege, hätte ich eine Frage.
Zwischen Gummi und Planetengetriebe (siehe Bilder Step 1+2) fallen im Betrieb schwarze Krümel raus…
Was könnte das sein (hart gewordenes Getriebefett)?
Danke
Peter
Hallo Peter
Da kann ich Dir leider nicht wirklich helfen.
Ich vermute eher verschüttete Lebensmittel.
Gruss Bruno
Hallo Bruno,
vielen Dank für die detailierte Anleitung. Mir ist es gelunge das grosse Kunststoffzahnrad abzuschrauben, obwohl das verlinkte Video nicht funktioniert. Bei mir ist aber der untere Getriebedeckel gebrochen. Daher meine Frage: wo beziehst du deine Ersatzteile? Die meisten kommen aus UK oder Italien oder aus “zur Zeit nicht lieferbar”. Gibt es noch eine schlaue Quelle die Dr. Google unbekannt ist?
Danke
Armin
Hallo Armin,
Bei mir ist ebenfalls der untere Getriebedeckel gebrochen. Wie hast du das Plastik Zahnrad entfernt? Bzw was hast du wie blockiert damit du es rausdrehen kannst? Wenn ich die Welle festhalte die vorne zu m rührstab runter geht ist die Übersetzung so stark dass ich Angst habe mir die Welle oder andere Zahnräder kaputt zu machen beim Versuch das plastikrad gegen den Uhrzeigersinn zu drehen. Hast du einen Tipp?
janis -
Hallo, super tolle Anleitung! Vielen Dank für Ihr Mühe.
Viele Grüße
Hallo Bruno,
bei meiner Maschine tropft unten beim Rührer manchmal Fett raus, ist das normal? Ich kann da auch keine Dichtung erkennen oder hast du eine Ahnung was kaputt sein könnte?
Vielen Dank schon mal für die Antwort!
Salut Andreas
Fett sollte da nicht raustropfen.
Im Schritt 8 ist eine Dichtung ersichtlich. Ich hatte sie mit Sanitärsilikon ersetzt.
Gruss Bruno
Hallo,
bei mir ist das Getriebe extrem voll mit zäh flüssigem Getriebefett. Habe das Gefühl dass der Widerstand zu groß ist. Maschine/Motor läuft zwar aber stottert etwas, als ob sie ab und zu gebremst wird.
Das zähflüssige Fett wird beim Drehen zwischen den Zahnflanken regelrecht raus gepresst und macht dabei Geräusche. Das habe ich im offenen Zustand beobachtet.
VG
Chris
