Kenwood Chef A701A Power Cable Replacement
  1. Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kenwood Chef A701A Power Cable Replacement, Remove Cable Grips: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the mixer upside down
    • Remove the two screws holding the white cable grip.
    • Remove the black cable grip. The long screw also holds the cover onto the terminal block
    My ‘black cable grip’ was a thin orange thing which broke when I removed it. Any suggestions about what I could use to make another please? I tried a strip of vinyl flooring but the screw cut into it.
    Picasso - crwdns2934203:0crwdne2934203:0
    Try a cable grip, e.g. from Amazon.
    VauWeh -
  2. Kenwood Chef A701A Power Cable Replacement, Remove the old cable: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable cover to expose the terminal block.
    • Remove the wires from the live and neutral terminals.
    • Thread the cables out though the cover and then from the mixer chassis
    • To refit simply follow the removal process in reverse
    • Be sure to connect the wires to the correct terminals, Brown - Live, Blue, Neutral.
    • If fitting a new plug ensure it is fitted with the appropriate fuse. If in any doubt consult a compitent electrician/electrical engineer
    Thank you so much. My Chef stopped working and replacing the cable fixed it.
    When you replace the cable, ensure it has enough play for the mixer to open.
crwdns2935229:05crwdne2935229:0
Grant
crwdns2935283:009/29/15crwdne2935283:0
173 crwdns2915208:0crwdne2915208:0
Important addition: make sure you leave enough cable length free under the mixer for when you raise the top of the mixer during use to change accessories or remove the bowl. Our local electrical repair shop didn’t think to do this and as soon as I raised the top the cable was pulled out.
Karen Leach - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 10,146
