Kensington Slimblade Trackball Disassembly
  1. Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ball and flip the base over.
    • Take off the rubber feet hiding 4 Phillips (PH1) screws using a spudger.
    • Remove the rubber crown hiding 3 small Phillips (PH0) screws.
    • Remove the seven screws.
  2. Kensington Slimblade Trackball Disassembly, Opening the Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Opening the Case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Opening the Case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening pick, pry up the lower case from the bottom.
    • Tilt the lower case to the left to access the USB cable that is routed through a channel in the lower case.
    • Loosen the cable retainer to free the lower housing.
  3. Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the retaining lever of the ZIF connector on the horizontal optical sensor.
    • Remove the cable from the connector.
    • Flip up the retaining lever of the ZIF connector on the vertical optical sensor.
    • Remove the 3 Phillips PH0 screws securing the circuit board. They are marked with white circles.
    • Remove the circuit board by carefully lifting with a spudger. Place it on a stable support to dust off the micro contacts.
  4. Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Dust the button contacts by pressing on them with a spudger and blowing into them with a hand blower. Repeat ten to twenty times for each of the four contacts.
    • Remove the screws from the horizontal displacement sensor.
    • Dust the sensor as needed. (This one is surprisingly clean.)
    • Do the same for the vertical displacement sensor.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Ludovic
crwdns2935283:009/18/17crwdne2935283:0
761 crwdns2915208:0crwdne2915208:0
Francophones crwdns2935289:0Francophonescrwdne2935289:0
Community
crwdns2931471:053crwdne2931471:0
crwdns2935297:040crwdne2935297:0
Thanks a lot for this tutorial. I have successfully removed the annoying speaker in it. Do you have any suggestions for trackball lubricant. its not smooth when it gets dry.
Akhil - crwdns2934203:0crwdne2934203:0
Hi Akhil,
Sorry for this late answer.
If it s not smooth, first clean the ball and the 3 steel points. Dust and fiber may accumulate around them. Once all is clear and dry, it may work. If you feel it's not enough, you can roll the ball in your hair. Sebum is a good lubricant.
I hope it will increase your confort.
Ludovic - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 135
crwdns2942667:0crwdne2942667:0 3,349
