Remove the screws the hold down the control console. There is one screw on each side. The screws are #1 philips.
Slide the control panel forward in order to expose the control panel controls and wiring.
Note the tabs slide into the holes.
The start switch is in the right side of the exposed control panel.
Remove the two wire clips from the tabs on the switch. Note black on top white/red on the bottom.
Lift the tab on the lower part of the switch and turn to the right to remove.
