Here we have a Kenmore 90 Series that will not start its spin cycle. This occurs when the motor coupler connected to the drive motor has been worn over time. In this guide, you will will learn the step-by-step process of replacing this component. Prior to beginning your repair, be sure to unplug the washing machine.
Using a flat head screwdriver, gently wedge the end caps off of the control console in order to open it up.
Unplug the lid-switch secured under the console.
Remove the console clips using a flat head screwdriver to release the chassis.
Stand in front of the washer and remove the chassis by lifting and pulling it towards you to expose the lower components.
Use the flat head screwdriver to flip the restraining clips and release the drain pump.
Remove the drive motor by unplugging the motor connector.
Place the drive motor to the side and remove the direct drive coupler by sliding it off.
