Kenmore 400 Washer clutch band Replacement
  1. Kenmore 400 Washer clutch band Replacement, Clutch band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement, Clutch band: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement, Clutch band: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Kenmore 400 washer that has difficulty spinning. It runs through the cycle but does not spin properly.
    • Open the lid
    • Remove cap from the agitator by using a flat tip screwdriver or similar.
  2. Kenmore 400 Washer clutch band Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the cap removed, a 7/16 hex bolt becomes visible.
    • Use a socket wrench with 4 inch extension to remove the bolt.
    • The agitator bolt measures 5/16 X 1 inches, 24 thread size
  3. Kenmore 400 Washer clutch band Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the bolt removed, pull the agitator of the shaft.
    • View of the drum with agitator removed
    • For ease of working on the bottom parts, lay the washer on its side.
  4. Kenmore 400 Washer clutch band Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Main parts of the assembly include
    • Drain pump
    • Motor
    • Transmission
    • This is a direct drive model. No belts but a motor coupler connects the motor to transmission. Check for any cracks etc.
    • Remove the wiring harness from the motor
  5. Kenmore 400 Washer clutch band Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the wiring harness from the clip on the transmission
    • Drain lines from the drum and drain hose are connected to the pump with spring clamps.
    • Using a pair of pliers and squeezinge the opposite ends of the clamps together will loosen the clamp.
  6. Kenmore 400 Washer clutch band Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the drain hose of the pump
    • Remove the tub-to-pump hose the same way
    • Remove the three 1/2inch bolts.
  7. Kenmore 400 Washer clutch band Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here are the three bolts. They are 5/16 by 11/16 with a 1/2 inch hex head.
    • With the three bolts removed, pull the complete assembly out of the drum
    • With the assembly removed, the clutch is now completely visible.
  8. Kenmore 400 Washer clutch band Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 400 Washer clutch band Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It is not necessary to replace the whole clutch. For this repair only the clutch band needs to be replaced
    • Using a pair of pliers to compress the spring will loosen the clutch band.
    • Lift the clutch band out of the clutch housing
    • Clutch band removed. Replace with model specific part.
crwdns2935229:011crwdne2935229:0
oldturkey03
crwdns2935283:009/29/10crwdne2935283:0
833,910 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
crwdns2947412:018crwdne2947412:0
Would this repair fix a 80 series Kenmore washer with same problem of no high-speed spinning
Larry Simonetta - crwdns2934203:0crwdne2934203:0
Possibly but it depends on what is going on with it. This one spun just sluggish and not „forcefull“ enough. It pretty much stopped spinning with a full load because of the weak clutch
oldturkey03 -
How much do it cost to repair it
Ralph Lingelbach - crwdns2934203:0crwdne2934203:0
The complete repair kit was somewhere between USD $30-$40
oldturkey03 -
I'm a jack of all if I can get it out I can rebuild it im a maintenance man at chicken proscenium plant we got to fixs all of it
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 75
crwdns2936753:030crwdne2936753:0 312
crwdns2942667:0crwdne2942667:0 34,727
