Kenmore 110 Series Washing Machine Water Level Sensor Replacement
  1. Kenmore 110 Series Washing Machine Water Level Sensor Replacement, Water Level Sensor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Water Level Sensor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kenmore 110 Series Washing Machine Water Level Sensor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove wires from water level sensor.
    • With a Phillips screwdriver remove the mounting screw.
    • Cut the zip tie and remove water level hose.
crwdns2935229:05crwdne2935229:0
Robert Trout
crwdns2935283:009/26/12crwdne2935283:0
1,234 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-43, Forte Fall 2012 crwdns2935289:0Cal Poly, Team 15-43, Forte Fall 2012crwdne2935289:0
CPSU-FORTE-F12S15G43
crwdns2935297:011crwdne2935297:0
crwdns2944067:04crwdne2944067:0
how to test water level switch??
countryrhoads4x4 - crwdns2934203:0crwdne2934203:0
What is the water sensor part # for a Kenmore model #11029842990?
Who has that part 4the best price?
Rod Brannon - crwdns2934203:0crwdne2934203:0
Hi,
I replaced the water-level pressure switch with a new kit but it did not resolve my problem. After installing the switch and line, I selected the lowest level but the tub continued to fill beyond the smallest wash level. I have a Kenmore Model # 110.20902. What other part or solution could resolve my issue?
BTW: I read replacing the water inlet valve night be involved but I already did that within the last six months and everything worked fine until I noticed the water level had changed the last two washes to a large load only. In fact, the water looked above the large level during my last wash.
I would appreciate any insight.
Shannon
Shannon - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 148
crwdns2942667:0crwdne2942667:0 39,799
