Use this guide to replace a worn drive belt in a Kenmore 110 Series Washing Machine.
Lay the washing machine on its back.
Using a 5/16" socket wrench, remove both screws from the belt cover.
Remove the belt cover from the washer.
Using a 1/2" socket, remove the bolt securing the drive pulley.
Remove the drive pulley and belt.
I have difficulty to remove the bolt suring the pulley. Is there any tricky to move the bolt?
need to remove shaft off pulley
I have a very old Kenmore Washer. The belt is loose but not broken. How do I tighten?
Thank you for the help .
what is the shaft? we can't get our on either
How can I Kno if it's the motor coupler or belt? Around the coupler is white plastic shavings.
The new belt is rigid and we're unable to stretch around the larger wheel. Any tricks?
crwdns2935229:017crwdne2935229:0
crwdns2944067:08crwdne2944067:0
What would be reason that rinse cycle doesn't spin and it leaks
Will the drive belt make a clicking/grinding noise? I originally thought it was just a slipping noise, but empty it does make the grinding noise.
It makes noise like it’s working but it’s not grabbing anything
You can change your gearbox
What belt type should I use for a 110.24642300? I cannot find its belt online.
I have a Kenmore washer model # 110.16852500 I need the belt for this washer please it gives me everything but the belt
یک وبسایت تخصصی توی بحث تعمیرات ماشین لباسشویی در مشهد سایت مشهد تعمیر هستش که نمایندگی رسمی بیشتر از ۳۰ برند مانند سامسونگ الجی دوو بوش اسنوا ایندزیت و... هستش
How to tell if it's belt or coupler? I have white plastic shavings around it.
