This guide shows how to remove and replace the vacuum motor for a Karcher Vacuum Universal 14286230 2014.
When you perform this repair, it is a good opportunity to replace the two rubber motor seals:
- Part 6.903-300.0 (69033000)
- Part 6.903-246.0 (69032460)
Release the two latches locking the top assembly in place.
Lift and remove the top assembly from the tank.
Remove the four T15 screws securing the top assembly.
Carefully lift the motor/filter away from the housing until you can access the motor wires.
Disconnect the two motor wires from the motor by pulling them straight out of their sockets.
You can now fully remove the motor/filter assembly from the housing.
Reassembly tip: Use the alignment tab to help you align the motor/filter with the housing assembly.
Remove the four T15 screws securing the motor flange.
Lift the motor flange and remove it from the motor assembly.
Re-assembly tip: Use the marked notch to help you align the motor flange to the assembly.
Lift the motor straight out of the assembly and remove it.
Peel and remove the two black rubber seals from the motor.
Transfer the rubber seals to the replacement motor.
crwdns2935229:05crwdne2935229:0
Part number for the filter nut: Karcher NT 27/1 48/1 Vacuum Hoover Holder Filtering Basket 9.411-954.0
