Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement
  1. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the tank: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the tank: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, make sure to power off and unplug the device.
    • Lift the tank by the handle and remove it from the device.
  2. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the transport wheels: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the yellow button near each wheel base to release the wheels.
    • Remove both wheels from their sockets.
  3. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T20 driver to remove the three screws securing the pump cover.
  4. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the pump cover.
  5. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Disconnect the pump: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Disconnect the pump: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the middle plug by the edges and pull it out of its socket.
    • During reassembly, make sure that all plugs are firmly seated in their sockets.
  6. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump bearings: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the pump assembly out of its recess.
    • Reassembly tip: make sure that the output hose end is fully secured to the housing socket.
  7. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the two rubber bearings away from the pump.
  8. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Feed the pump plug through the rubber bushing's cutout.
  9. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the black check valve off the pump's output port.
  10. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the clear hose off the pump's input port.
  11. Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Rotary Floor Cleaner 17833080 2017 Pump Replacement, Remove the pump: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the pump.
    • Reassembly tip: be careful not to mix the pump's input and output. The arrow points towards the pump output, which should connect to the black check valve.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
297,091 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,312crwdne2935297:0
crwdns2942667:0crwdne2942667:0 708
