This guide shows how to remove and replace the motor that drives the roller brushes for the Karcher Rotary Floor Cleaner 17833080 2017.
Lift the tank by the handle and remove it from the device.
Press the yellow button near each wheel base to release the wheels.
Remove both wheels from their sockets.
Press the yellow foot switch at the base of the device to lower the suction bars.
Raise the handle to the upright position.
Engage the retaining bracket to lock the handle in place.
Grasp the handle and carefully tilt the device onto its side.
Tilt the top of the roller brush out of the brush well.
Remove both roller brushes.
Press the yellow button on the suction bar retaining bracket to release the suction bar.
Remove both suction bars.
Reassembly tip: When you re-insert the suction bars, be sure to orient the locking tab towards the center of the device. This allows the bars to click in place.
Use a T20 driver to remove the three screws securing the pump cover.
Squeeze the right plug by the edges and pull it out of its socket.
Remove the following screws securing the left retaining bracket:
Four T40 screws
Two T20 screws
Use a T20 driver to remove the two screws securing the right splash guard.
Use a T20 driver to remove the following screws securing the right retaining bracket:
Two 85 mm-long screws
Four 45 mm-long screws
Lift the handle assembly away from the device and remove it.
Disconnect the two remaining plugs by squeezing the edges and pulling them out of their sockets.
Vacuum motor
Pump
Handle
Use a T20 driver to remove the six screws securing the plastic brush housing.
Lift the brush housing away from the device and remove it.
Use a T20 driver to remove the two screws securing the socket board.
Squeeze the edges of the drive motor plug and disconnect it from the extension plug.
Free the motor wires from underneath the socket board.
Use a T20 driver to remove the six bolts securing the gear case cover.
Remove the following bolts from the gear case:
Six T20 bolts
One T30 bolt securing the ground wire
Lift the motor end of the drive assembly up slightly to clear the mounting lip.
Push the drive assembly out of its recess.
Remove the drive assembly and stand it on the motor end.
Use snap ring pliers to remove the retaining ring securing the motor axle.
Use a T30 driver to remove the three bolts securing the gear case to the motor mount.
Use a pry bar or flathead screwdriver to loosen the gear case from the motor mount.
Lift the gear case away from the motor mount to remove it.
The motor axle is keyed into the gearbox. Rotate the axle until it aligns with the gearbox slot.
Align the gear case to the motor mount using the two alignment pins.
Once everything is aligned, gently tap the gear case onto the motor mount.
Use a large flathead screwdriver or pry bar to pry the blower wheel off the motor axle.
Use a 1/2" (or 13 mm) socket to remove the four bolts securing the motor to its mount.
Remove the motor mount from the motor.
