Karcher Pressure Washers 15209900 2018 Motor Replacement
  1. Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Safety precautions: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • Unscrew the output hose from the pressure washer.
  2. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the rubber strap: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlatch and remove the yellow rubber strap.
  3. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the hand grip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T20 driver to remove the two 55mm-long screws securing the hand grip.
  4. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the hand grip: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the hand grip: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the hand grip from the extension bars.
  5. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the top panels: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the top panels: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T15 driver to remove the six screws securing the top black plastic panels on either side of the device.
  6. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the top panels: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two plastic panels.
  7. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the plastic feet: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the plastic feet: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two T15 screws securing the plastic feet—one screw on either side.
  8. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plastic feet: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unclip and remove the plastic feet.
  9. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the housing: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the housing: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T15 driver to remove the ten screws securing the housing halves together.
    • Remove the T15 screw underneath the wheel axle.
  10. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the housing: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the housing: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set the device on its side.
    • Lift the housing half away from the body.
    • If the housing half does not separate, check to make sure you removed all the body screws.
    • Remove the housing.
    • Screws may get stuck inside the plastic housing. Be careful not to lose any screws.
  11. Karcher Pressure Washers 15209900 2018 Motor Replacement, Release the cord strain relief: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Release the cord strain relief: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the power cord strain relief out its notch on the plastic housing.
  12. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motor assembly out of the plastic housing and set it aside.
  13. Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Reassembly tip: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reassembly tip: Use these images to help reassemble the housing back around the motor.
    • Make sure that all five bushings are in place.
    • In order for the housing to fit properly, the bushings must fit in their respective mounts.
    • Make sure that the yellow tube is properly notched onto the housing.
    • Make sure that the power cord strain relief sits correctly in the housing notch.
  14. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the electrical box cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T20 driver to remove the four screws securing the electrical box cover.
  15. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the cover off of the electrical box.
  16. Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the capacitor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the capacitor: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the capacitor upward slightly to gain access to the connectors.
  17. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Unplug the capacitor: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull each capacitor connector directly off of their spade plug.
  18. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the capacitor: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the capacitor.
    • Reassembly note: The wires are non-polarized and can connect into either plug on the capacitor.
  19. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plate spring: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the plate spring: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plate spring from the electrical box.
  20. Karcher Pressure Washers 15209900 2018 Motor Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the switch out of the electrical box.
    • Disconnect the four spade connectors from the the switch.
  21. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the switch: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the switch: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the switch.
    • Reassembly tip: Use the second photo as a reference to help you properly re-wire the switch.
  22. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the grounding screw: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a flat head screwdriver to remove the screw securing the ground wire in the electrical box.
  23. Karcher Pressure Washers 15209900 2018 Motor Replacement, Unscrew the electrical box: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T30 driver to remove the two bolts securing the electrical box to the motor assembly.
  24. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the electrical box: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the electrical box away from the motor assembly, taking care to feed the wires through the cutout.
    • Remove the electrical box.
  25. Karcher Pressure Washers 15209900 2018 Motor Replacement, Set the motor upright: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the motor assembly upright with the pump assembly on the top.
    • The pump assembly is filled with oil. This step prevents the oil from spilling out when you remove the pump.
  26. Karcher Pressure Washers 15209900 2018 Motor Replacement, Loosen the pump assembly: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 13mm socket to remove the four long bolts holding the pump assembly to the motor.
    • Re-assembly tip: The bolts hold the pump under pressure against the motor assembly. During reassembly, gradually tighten the bolts in a cross pattern.
  27. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump assembly: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump assembly: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the pump assembly off of the motor.
  28. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the pump oil: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pour the pump oil out of the motor housing. If the oil looks serviceable, save it for reassembly.
    • Reassembly tip: The piston assembly is sealed with oil, and the motor housing acts as an oil pan. Before you attach the pump to the motor, fill the piston well with oil, up to the bearing plate.
  29. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the bearing plate: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bearing plate from the motor assembly.
    • Reassembly tip: The side of the plate with the ringed groove should face the bearings.
  30. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the bearing ring: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bearing ring.
  31. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor bushings: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the two rubber bushings off of each side of the motor.
  32. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the motor cover: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the black motor cover off of the motor assembly.
  33. Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Pressure Washers 15209900 2018 Motor Replacement, Remove the blower wheel: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a pry bar or a flat head screwdriver between the blower wheel and the motor assembly.
    • Pry to loosen the blower wheel from the motor.
    • Slide the blower wheel off of the motor assembly.
  34. Karcher Pressure Washers 15209900 2018 Motor Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Only the motor assembly remains.
Arthur Shi
crwdns2935283:001/03/18crwdne2935283:0
298,328 crwdns2915208:0crwdne2915208:0
crwdns2935297:0683crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,924crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,287
