Use this guide to remove and replace a pump in a Karcher Carpet Cleaner BRC3015C 2018.
This guide shows the removal process for just one pump. If you wish to remove the other pump, you may apply these same steps to remove it.
Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
Use a 3 mm hex key to remove two bolts securing the bottom cover.
Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
Use a 3 mm hex key to remove the four bolts securing the pump cover.
As with the other comment above, it’s a 4mm Hex key, not a 3mm.
Use a flathead screwdriver to loosen the hose clamps at both ends of the pump.
Pull the hoses at both ends of the pump straight off of their hose barbs to remove them.
Use your fingers to unscrew the hose barb from the outward-facing end of the pump.
Bend the outer side of the pump compartment away from the pump very slightly.
Slide the pump out of the hole in the side of the pump compartment, then continue to slide the pump out of the compartment.
Use a Phillips #2 screwdriver to remove the screw securing the ground wire to the pump.
Remove the ground wire from the pump.
Pull the two connectors straight off of the pump to disconnect them from the pump.
Use your fingers to unscrew the remaining hose barb from the pump.
, Yes, why show how to replace it if you cant even buy it? top msg says:
( Karcher Pump, 110/120V 60Hz Flojet 86201110 Not for sale)
Ask Google for “Kärcher 8.620-111.0”
VauWeh -
The one we have has 4 mm screws. Otherwise, very helpful, thanks.
