Karcher Carpet Cleaner 10066730 2014 Heater Replacement
  1. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the device down: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the device down: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the device down: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before beginning repairs, disconnect the device from power, disconnect all hoses, drain and depressurize the system, and let the device cool if the heater was recently used.
    • Lower the device down so it is laying on its backside, bottom facing out.
  2. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wing nuts: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two wing nuts securing the base to the device.
    • The base is heavy, so be prepared to lower it down slowly once the wing nuts are removed.
  3. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the base down: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the base down: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Lower the base down: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lower the base down until the swivel wheels touch the ground.
  4. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Free the hoses: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an 11 mm socket to remove the nut and washer securing the hose retainer clamps.
  5. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of flush cutters or sharp scissors to cut the zip tie securing the two hoses together.
    • Pull the hose retaining clamps off of the bolt they were secured by.
    • During reassembly, install a new zip tie.
  6. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the output hose: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the output hose: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a crescent wrench to loosen the 11/16 inch water output hose fitting on the heater.
  7. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the water output hose from its fitting on the heater.
    • Place a shop rag underneath the fitting to catch any drips.
    • Add fresh plumber's tape to the fitting when reinstalling.
  8. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the input hose: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the input hose: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a crescent wrench to loosen the 9/16 inch water input hose fitting on the heater.
  9. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the water input hose from its fitting on the heater.
  10. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Unmount the heater: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a large flathead screwdriver to loosen the pie clamps securing the heater.
  11. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull both pie clamps apart, freeing the heater.
  12. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Roll the heater down and pull it left, away from the device to remove it.
    • Be careful to not snag any hoses when removing the heater.
    • Do not attempt to fully remove the heater yet, as it is still connected to power.
  13. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wires from the heater: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wires from the heater: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the wires from the heater: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Keep track of which wire goes where, marking wires with tape if you need to.
    • Grip the black ground jumper wire by its blue connector and pull directly away from the heater to remove it.
    • Remove the other side of the black ground jumper wire.
  14. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the tan power wire by its blue connector and pull directly away from the heater to remove it.
  15. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the tan and white wires.
  16. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the brown intermittent power wire by its blue connector and pull directly away from the heater to remove it.
  17. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 3/8 inch socket to remove the nut securing the ground wires.
  18. Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Karcher Carpet Cleaner 10066730 2014 Heater Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the heater's green ground wire from the stack.
    • The heater's wire should be the upmost wire in the stack after removing the nut.
  19. Karcher Carpet Cleaner 10066730 2014 Heater Replacement, Remove the heater: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the heater.
Carsten Frauenheim
146,268 crwdns2915208:0crwdne2915208:0
crwdns2935297:0424crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,980crwdne2935297:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,304
