Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement
  1. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Removing Front Panel Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Removing Front Panel Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 6x 2.5mm Hex screws on the left and right side of the roaster.
    • Take care not to damage the buttons while maneuvering the front panel, with all six screws removed it may fall away.
  2. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Lift the closure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Lift the closure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the front panel steady while removing the plastic top/closure.
  3. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Removing the front panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull away the front panel carefully.
  4. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Removing the rear panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Removing the rear panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Removing the rear panel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the last 2.5mm Hex screw securing the rear panel.
    • Pull up on the rear panel to remove it from the roaster.
  5. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Access granted: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Access granted: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set the panels aside somewhere safe and bask in the beauty of your naked roaster.
  6. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Disconnect the thermocouple: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Disconnect the thermocouple: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Disconnect the thermocouple: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 2.0mm slotted screwdriver to remove the thermocouple wires from the PCB-A
  7. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Disconnect the motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Disconnect the motor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the motor cable, this may take some wiggling.
    • Refrain from using pliers or metal tools on this connector, as the plastic insulation can be damaged.
  8. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Disconnect the SSR signal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Disconnect the SSR signal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull upwards on the SSR signal connector to remove it.
  9. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the cable carrier: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the cable carrier: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the cable carrier: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2x 2.5mm Hex screws securing the cable carrier to the base.
    • Be careful not to lay the roaster on its front as the buttons can be damaged or broken off.
  10. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the ribbon connector: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the ribbon connector: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the ribbon connector.
  11. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove PCB screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 4x PH2 PCB screws.
    • These screws are captive to the PCB.
  12. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the PCB: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the PCB: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the PCB: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the PCB away from the base assembly.
    • Use pliers to disconnect the transformer secondary wires from the back of the PCB
    • The transformer wires may be reconnected in either orientation. If you are replacing the USB daughterboard, you can choose to leave these wires in place.
  13. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove shroud screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove shroud screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove shroud screws: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 2x 1.5mm hex screws securing the plastic USB shroud.
  14. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove shroud: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the plastic shroud away from the PCB
  15. Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the daughterboard: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Kaffelogic Nano 7/LINK (D-P Serial) USB Daughterboard Replacement, Remove the daughterboard: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull away on the daughterboard to remove it from the main PCB.
Kaffelogic
crwdns2935283:007/23/25crwdne2935283:0
46 crwdns2915208:0crwdne2915208:0
crwdns2935297:017crwdne2935297:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 45
